It is currently Wed Nov 18, 2026 10:58 am
 Post subject: broken bolt 8-1/4
PostPosted: Sat Apr 25, 2009 7:36 pm
I managed to twist off the head of one of the U-Joint strap bolts today while reinstalling the drive shaft. I figure getting the bolt out will be fun but doable. My question is are the bolts the same from a '73 7-1/4?
PostPosted: Sat Apr 25, 2009 9:07 pm
Same little bolt, yes. See if you can pick up a small LH drill bit.
PostPosted: Sun Apr 26, 2009 5:52 am
Time for a new yoke.
