| broken chain https://slantsix.org/forum/viewtopic.php?t=35034 |
| Author: | turboram [ Sat Apr 25, 2009 6:08 am ] |
| Post subject: | broken chain |
Last night I was driving my truck and snap! the motor went silent. Also can anyone tell me if this is an interfirence engine,my cam has .460 lift.I may try a used set to do a compression test today |
| Author: | sandy in BC [ Sat Apr 25, 2009 6:18 am ] |
Its not an interference motor. Until you have a new chain you wont be able to do a compression check. Sounds like the cam stopped turning and the crank kept goin' What does the OPDG look like? Any bent pushrods? |
| Author: | terrylittlejohn [ Sat Apr 25, 2009 11:56 am ] |
you better check the cam pin and crank keyway for damage |
| Author: | Dart270 [ Sun Apr 26, 2009 5:14 am ] |
What type of chain? Lou |
| Author: | slantzilla [ Sun Apr 26, 2009 5:58 am ] |
Oil pump failure. |
| Author: | turboram [ Sun Apr 26, 2009 3:23 pm ] |
Its a melling timing set. I put a used set on yesterday and the compression is good and it also pumps oil.but I will pull the distributor plug and check the gears.I'm just wandering what would cause the failure. Ill post picture soon |
| Author: | terrylittlejohn [ Sun Apr 26, 2009 6:04 pm ] |
have you drain the oil to see were all the metal from the gear is? if it`s in the sump the pan is going to have to be flushed out. |
| Author: | turboram [ Mon Apr 27, 2009 5:17 am ] |
every tooth was shorn off and was in the front of the pan fished them out with a magnet.The teeth show no wear |
| Author: | dakight [ Mon Apr 27, 2009 5:21 am ] |
It sheared the teeth from a steel cam gear? |
| Author: | Joshie225 [ Mon Apr 27, 2009 8:11 am ] |
A friend's Cheby ate the timing set and hurt the damper when the crank broke. |
| Author: | turboram [ Mon Apr 27, 2009 1:16 pm ] |
| Post subject: | pictures |
heres the carnage
| Author: | THOR [ Mon Apr 27, 2009 6:28 pm ] |
Holy crap.... ~THOR~ |
| Author: | bigslant6fan [ Mon Apr 27, 2009 8:34 pm ] |
| Post subject: | tc |
I agree with Slantzilla,something else is wrong and caused the timing chain to fail.Either the oil pump or cam bearings are bad. |
