| Electric choke? https://slantsix.org/forum/viewtopic.php?t=35035 |
| Author: | Rick Covalt [ Sat Apr 25, 2009 6:11 am ] |
| Post subject: | Electric choke? |
Ryan's Dart is running now so we are wrapping up some of the small things and then off to the alignment shop. It has a 600 Holley with electric choke. Question for anyone that is running the electric choke. Where did you tie in your switched 12V too. Just looking for a clean easy place to tie into. Wondering what others may have done. Thanks, Rick PS. The corner of the plastic is broken but it still works Ok. If anyone has a barrel full of Holleys and may have the electric choke element let me know. I know new ones are out there but they are $25 + I'm sure I can pick one up for less than that. Thanks. |
| Author: | Aggressive Ted [ Sat Apr 25, 2009 7:15 am ] |
Off the ignition or plus/incoming side of the ballast resistor. |
| Author: | Rick Covalt [ Sat Apr 25, 2009 1:50 pm ] |
| Post subject: | My Way |
Well, Since we had just installed an MSD unit on Ryan's Dart and the old brown wire to the coil is unused, I decided to put that wire top good use. I put a connector on the end and extended it on around the front with the wire that runs to the Temperature sending unit and then back around to the electric choke unit. Enclosed those 2 wires in some nice loom and it looks good to boot. Thanks, Rick |
