| Thinking again hmmmmm https://slantsix.org/forum/viewtopic.php?t=35040 |
| Author: | 00spy [ Sat Apr 25, 2009 2:18 pm ] |
| Post subject: | Thinking again hmmmmm |
This is another example of an idle mind is the devils playground. I know it is stupid , but came to mind , what if you put like a cpu cooling fan at the end part of the air cleaner for the air ducting . and wire it to come on when running. Dave |
| Author: | emsvitil [ Sat Apr 25, 2009 2:23 pm ] |
You'll have less airflow as it will be more of a restriction than help. |
| Author: | 00spy [ Sat Apr 25, 2009 2:30 pm ] |
Thats true , I was cleaning up some , came upon one , and everything I find, I think can this be used somehow.I know I think too much Dave |
| Author: | Andy's GT [ Sat Apr 25, 2009 2:31 pm ] |
i thought the same thing when i discovered they were 12v, but in addition to blocking the airway i dont think they spin near fast enough to do anything. i briefly thought about wiring one to my amp to keep it cooler, but never did that either... |
| Author: | stonethk [ Sat Apr 25, 2009 2:36 pm ] |
Mount it on your dash for summer, cheap non AC car alternative. Get some hi-tec in that old car |
| Author: | 00spy [ Sat Apr 25, 2009 2:40 pm ] |
Quote: Mount it on your dash for summer, cheap non AC car alternative. Get some hi-tec in that old car
note to self............ buy a dozen cpu cooling fans. Dave |
| Author: | MichaelS [ Sun Apr 26, 2009 5:59 am ] |
Plumb your air conditioner into the air cleaner for a nice blast of cold air! |
| Author: | 00spy [ Sun Apr 26, 2009 6:41 am ] |
Now you are being silly ( I don't have A/C) Dave |
| Author: | MichaelS [ Sun Apr 26, 2009 7:47 am ] |
There is a comercially made devise that dose exactly what you are suggesting. It has a small fan that ducts to your air intake and they claim more MPG and power. Ha the fan is smaller than a ps fan! |
| Author: | Reed [ Sun Apr 26, 2009 8:05 am ] |
get a small solar panel and fabricate a housing for the panel and the CPU fan and build a device which will fit over a mostly rolled up window to circulate air in the car while it is parked. |
| Author: | stonethk [ Sun Apr 26, 2009 8:18 am ] |
Quote: get a small solar panel and fabricate a housing for the panel and the CPU fan and build a device which will fit over a mostly rolled up window to circulate air in the car while it is parked.
Modern day swamp cooler?
| Author: | MichaelS [ Sun Apr 26, 2009 9:23 am ] |
You mean like this? I think the cpu fan might work better. http://news.cnet.com/8301-10784_3-6079960-7.html |
| Author: | Reed [ Sun Apr 26, 2009 9:27 am ] |
Yeah! |
