It is currently Wed Nov 18, 2026 12:12 am
 Post subject: want to swap slant sixes
PostPosted: Sat Apr 25, 2009 8:10 pm
ok well i have a 1984 dodge d100 with a slant six and a A833 4sp and its getting kinda tired so i went searchin for another and found one thats in a 69 duster but its automatic and i've heard from some people that a automatic slant six will not bolt up to a a833 cause the input shaft wont fit cause its to big....any body wanna help me here?
PostPosted: Sat Apr 25, 2009 9:08 pm
You have to check the crank in the donor engine to see if it's drilled for a pilot bushing. Most are. If it's drilled, but not reamed for the bushing you can use the late model roller pilot bearing.
PostPosted: Mon Apr 27, 2009 7:14 am
what would you recommend taking a pilot bushing from?
PostPosted: Mon Apr 27, 2009 8:19 am
The pilot bushing you buy new.
