| Header Wrap https://slantsix.org/forum/viewtopic.php?t=35066 |
| Author: | ceej [ Mon Apr 27, 2009 10:09 am ] |
| Post subject: | Header Wrap |
I tried something novel. I read the instructions on the can of DEI Sealer for the header wrap. It says to cure at 400°F That's all fine and good, but the dual dutra headpipe I built won't fit in the oven, and even if it could, I don't think being beaten to within an inch of my life by a crazed woman for sticking it in there is going to fly. Any thoughts on the curing process? I think I'm stuck with ambient curing for this. Good enough, or do I need to create a curing chamber and employ my turkey fryer burner? CJ |
| Author: | Joshie225 [ Mon Apr 27, 2009 10:50 am ] |
Do you have a heat gun you can stick in the pipe? |
| Author: | ceej [ Mon Apr 27, 2009 11:12 am ] |
That I can do. I'll go check it out of the shop for the evening! Good idea! CJ |
| Author: | Joshie225 [ Mon Apr 27, 2009 11:46 am ] |
Glad to be of assistance! |
| Author: | emsvitil [ Mon Apr 27, 2009 3:38 pm ] |
Wouldn't running the engine do the trick? |
| Author: | wicked/six [ Mon Apr 27, 2009 4:32 pm ] |
![]() Not done yet so don't try to be funny and point out the zip ties!!! TF |
| Author: | ceej [ Tue Apr 28, 2009 7:01 am ] |
The heat gun got things nice and warm, but I'm not sure how "Hot" It got. Certainly not 400° with an ambient temperature of 60° in the shop. I let the heat gun run for about four hours. Tonight I'll mount the head pipe up and then fire the Engine for a bit. Not hot, just put a bit of heat to it, then let it soak. Battle of Detroit on Saturday at Woodburn! Gotta get this crate moving! CJ |
| Author: | ceej [ Wed Apr 29, 2009 6:08 pm ] |
Tightened everything down tonight, and took a little drive. The engine compartment is considerably cooler. The sound level in the car dropped remarkably. In the engine compartment it's considerably quieter also. An added benefit! When I was tightening the head pipe to the rear dual, the wrench came down on the wiring harness. I knew I was in trouble right then and there. My temperature gauge doesn't work anymore. At least I know what happened. Time to run a new wire. Dang. CJ |
| Author: | Wesola78 [ Fri Jun 05, 2009 10:00 am ] |
I have a Dutra manifold, and a modified manifold under the hood of my Volare. Would I see any benefit if I wrapped these manifolds? This is a daily driver, not a race car. Thanks for ya'll's opinions! |
