It is currently Mon Oct 26, 2026 10:04 am
PostPosted: Fri May 01, 2009 11:51 am
I have a '72 Duster, 225 with out a/c. I'm going to be installing the radiator, shroud and fan from a '72 Dart which was eqquiped with factory a/c. However I was unable to grab the upper and lower radiator hoses, so I do not have old hoses to match new ones to. I hope that someone may be able to post a few pictures to help.
Thanks, Chuck.
1972 Plymouth Duster 225
PostPosted: Fri May 01, 2009 2:04 pm
I recently did a similar conversion on my '72 Valiant...essentially upgraded to a/c cooling....The top rad inlet was shifted more towards the passenger side and I was unable to use my stock top hose. I bought an extra lower hose and with some trimming I made it work for the top....You should be ok using the stock lower hose in your conversion for the bottom....nico
PostPosted: Fri May 01, 2009 6:27 pm
You don't need pictures, you need part numbers. Just one part number, actually, for the top radiator hose: Gates 20230. The lower hose is the same with the small or big radiator, Gates 20949.
PostPosted: Sat May 02, 2009 3:18 am
Great! Thanks guys!
Users browsing this forum: Amazon [Bot], Bing [Bot] and 6 guests
