It is currently Thu Jul 16, 2026 9:44 am
PostPosted: Tue Apr 30, 2002 10:05 pm
Back in Dec: I had the oprotunity to put the old Hoopy on a friend's dyno. With a 390 holley adapted to a 2bbl intk, and electronic Ignition the 225 put out 97 Rear wheel HP and 153 fp of Torque.
After a .030 overbore, clifford intake and headers, Comp264s cam, minor head work, and a homemade windage tray....
This past weekend she ran 137HP at 178fp of torque.
I always figured HP is harder to get than the advertised figures of parts manufac.....but I am not disapointed in the results..the old bomb is running great. It would be interesting to know what kind of results others are getting at the rear wheels. I know most people can't afford the Dyno thing...I just have a good friend.
Anyway, I promised some of you guys that I would get back ...with the results
Trysix
Soupitup@msn.com
PostPosted: Tue Apr 30, 2002 10:36 pm
: Back in Dec: I had the oprotunity to put the
: old Hoopy on a friend's dyno. With a 390
: holley adapted to a 2bbl intk, and
: electronic Ignition the 225 put out 97 Rear
: wheel HP and 153 fp of Torque.
: After a .030 overbore, clifford intake and
: headers, Comp264s cam, minor head work, and
: a homemade windage tray....
: This past weekend she ran 137HP at 178fp of
: torque.
: I always figured HP is harder to get than the
: advertised figures of parts manufac.....but
: I am not disapointed in the results..the old
: bomb is running great. It would be
: interesting to know what kind of results
: others are getting at the rear wheels. I
: know most people can't afford the Dyno
: thing...I just have a good friend.
: Anyway, I promised some of you guys that I
: would get back ...with the results
: Trysix
40 more H.P. at the rear wheels, thats a great improvement.
Did you get a chance to try some different timing or carb settings? (My guess is that there are a few more "horses" hiding in there)
PostPosted: Wed May 01, 2002 2:52 pm
Depending on the kind of dyno you were using, typical driveline losses are 15-20%. So your crankshaft HP and TQ were in the 171/225 range.
Mitch
m5black@aol.com
PostPosted: Wed May 01, 2002 5:05 pm
: Depending on the kind of dyno you were using,
: typical driveline losses are 15-20%. So your
: crankshaft HP and TQ were in the 171/225
: range.
: Mitch
The Dyno owner mentioned the 15% thing to me....I just added the 40HP gain to the 145HP original factory advertised rating.....so as to get 185 HP....anyway it's just something to play with...
Trysix
Soupitup@msn.com
PostPosted: Wed May 01, 2002 5:20 pm
: 40 more H.P. at the rear wheels, thats a great
: improvement.
: Did you get a chance to try some different
: timing or carb settings? (My guess is that
: there are a few more "horses"
: hiding in there)
: DD
Doc:
The only thing that I played with was the rev limits and exhaust. I bumped my rev limit from 5.4 k to 5.6K and the curves stayed relatively flat with a little increase. I also remove the covers from my exhaust cut-outs located just before the mufflers at the rear axle. I only saw about a 2HP increase...if that.It did make a lot more racket though. I agree I feel there is more power in tuning....I still havent tried rejetting the carb and your right it would have been nice to play with the timming a bit. I plan on taking it to the racetrack soon ...maybe I'll find something there. I don't know what to expect from the 1/4 mile performance but I'm not real optimistic this cars a 4dr B body with
no fat removed.
Trysix
Soupitup@msn.com
PostPosted: Wed May 01, 2002 6:00 pm
I plan on putting mine on the dyno at the sometime this summer but how knows!!!
andrew wagner
: torque.
: Trysix
