| Weight & quantity of oil https://slantsix.org/forum/viewtopic.php?t=35110 |
| Author: | wjajr [ Wed Apr 29, 2009 9:05 am ] |
| Post subject: | Weight & quantity of oil |
Several questions: Is 90 weight gear oil + additive for Suregrip OK for 8 3/4" rear? Dextron III ok for A 904? (Non racing car with oil cooler) Dose cast deep base add extra two quarts of transmission fluid over factory pan? |
| Author: | Joshie225 [ Wed Apr 29, 2009 10:46 am ] |
| Post subject: | Re: Weight & quantity of oil |
Quote: Several questions:
80W-90 is more common and superior in most cases to SAE 90. GL-5 with the additive or GL-5+ can usually be used without the additive. No additive needed if you don't have Sure-Grip. Is 90 weight gear oil + additive for Suregrip OK for 8 3/4" rear? Quote: Dextron III ok for A 904? (Non racing car with oil cooler)
Dexron III is fine. Quote: Dose cast deep base add extra two quarts of transmission fluid over factory pan?
Capacity depends on the pan. I feel it's a waste of time and money at this performance level.
| Author: | wjajr [ Wed Apr 29, 2009 11:42 am ] |
Thanks Josh wjajr wrote: Quote: Quote: Dose cast deep base add extra two quarts of transmission fluid over factory pan? Capacity depends on the pan. I feel it's a waste of time and money at this performance level. |
