It is currently Sat Jun 13, 2026 6:11 pm
 Post subject: Cam Card
PostPosted: Wed May 06, 2009 6:36 am
Ryan's Dart is up and running with the Erson regrind cam in it. 510 lift / 282 duration. The spec sheet for the cam shows .023 hot for both intake and exhaust clearances. Why are they the same? I thought the exhaust was usually about .010 more clearance than the intake.
Thanks, Rick
PostPosted: Wed May 06, 2009 6:48 am
Rick
Each Cam Co. Set the lash up different. It also changes from grind to grind. Remember that its only a starting point and you can "play" with your lash to get more or less from your cam. It not a BIG change but a change none the less.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Wed May 06, 2009 7:27 am
Start with the cam grinder specs....then when the motor is running well try varying the lash for smooth idle and power production. I generally vary the lash about 2 thou each trial.
I ended up about 1-2 thou tighter on my Erson 280/270 (intake and exhaust)
 Post subject: Thanks
PostPosted: Wed May 06, 2009 1:36 pm
Well I will have to loosen up the intake to their specs and start there. I'm at .015 and .023 now. It idles pretty well after it is warmed up and I have about 14-15" vacuum. Is that about where I should be with a cam this size.
Thanks,
Rick
PostPosted: Wed May 06, 2009 1:58 pm
That is quite good vacuum for a cam that size.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 3 guests
