It is currently Wed Nov 25, 2026 12:05 am
 Post subject: 1975 driver subframe??
PostPosted: Sat May 02, 2009 2:55 am
my subframe for the tork-rod mount, needs to be replaced (rust out), are there any out there that are remade?? before I go through all the work to make one. any help would be the tops. also it is a slant6-auto trans-4dr car.
1930 Jordan Great Line "90", 1951 Chrysler Saratoga,1953 Plymouth, 1971 Honda CB 500 "4", 1973 Honda CB 350, 1975 Honda CB 500 twin, 1988 Honda Shadow 1340, 1975 Dodge Dart Custom, 1992 Dodge 2500 turbo truck,1975 Schwinn Collgate 5sp.
PostPosted: Sat May 02, 2009 3:15 am
Only one I know of is this pricy kit, however its labeled only up to 74. The 75-76 torsion bar mount may be a bit different, not sure.
 Post subject: Same...
PostPosted: Sat May 02, 2009 7:55 am
There is no change in the 75-76 model years for the frames...the pans are the same to, except for the driver's side floor pan has a provision for an aluminum heatsheild above the cat convertor and the two piece exhaust pipe has a hanger to support the rear pipe. I think vendors just are scared because they've never looked at a 75-76 and just don't know it's still the same "shell" as the 73-74...
PostPosted: Sat May 02, 2009 11:34 am
Too bad you weren't closer, I have a '76 Dart parts car that I would let you ravage. I'm in S.E. B.C. That's above Spokane for those of you that skipped your Canadian Geography class.
