| 1975 driver subframe?? https://slantsix.org/forum/viewtopic.php?t=35154 |
| Author: | hydrive1953 [ Sat May 02, 2009 2:55 am ] |
| Post subject: | 1975 driver subframe?? |
my subframe for the tork-rod mount, needs to be replaced (rust out), are there any out there that are remade?? before I go through all the work to make one. any help would be the tops. also it is a slant6-auto trans-4dr car. |
| Author: | Pierre [ Sat May 02, 2009 3:15 am ] |
Only one I know of is this pricy kit, however its labeled only up to 74. The 75-76 torsion bar mount may be a bit different, not sure. |
| Author: | DusterIdiot [ Sat May 02, 2009 7:55 am ] |
| Post subject: | Same... |
There is no change in the 75-76 model years for the frames...the pans are the same to, except for the driver's side floor pan has a provision for an aluminum heatsheild above the cat convertor and the two piece exhaust pipe has a hanger to support the rear pipe. I think vendors just are scared because they've never looked at a 75-76 and just don't know it's still the same "shell" as the 73-74... -D.Idiot |
| Author: | polara pat [ Sat May 02, 2009 11:34 am ] |
Too bad you weren't closer, I have a '76 Dart parts car that I would let you ravage. I'm in S.E. B.C. That's above Spokane for those of you that skipped your Canadian Geography class. |
