Oil burning
https://slantsix.org/forum/viewtopic.php?t=35159
Author:  68barracuda [ Sat May 02, 2009 11:04 am ]
Post subject:  Oil burning
Took delivery of the RSA Valiant Charger this week - did the whole service lash etc - compression is good - 125 - 128 psi but it is burning oil - if you rev it it increases - let go it decreases rev again and big smoke - rings or valvestems? car sat for a long time engine is tight for a 67000km car
BTW this thing is VERY torquey -
Author:  dakight [ Sun May 03, 2009 6:15 am ]
It sounds as though the oil rings may be stuck. Often a few hours of operation will free them up and reduce the smoking. Typically if it's valve seals you will see smoke when starting the engine after letting it sit for a while. Elsewhere on the board I believe there is a recipe for an engine flushing soup which you might find helpful. It certainly wouldn't hurt anything to replace the valve seals too.
Author:  68barracuda [ Sun May 03, 2009 7:25 am ]
I have the same feeling - I didnt replace the valve cover after lashiong the valves - and I noticed one or two seal not looking kosher :?
I had the advice to pour some WM Penn Valve ease down the carb as well.
Have flushed Wil do so again! - was thinking aboput pulling the head and checking out the cylinder bores - have the gaskets
Author:  Aggressive Ted [ Sun May 03, 2009 8:14 am ]
I would run some Rislone to help free up the oil rings for a oil change or two. They should seal right back up. It never hurts to install new valve seals. I saved many old SL6 Valiants and Darts when I worked at Bellingham Auto Wrecking during my college days. You can use a half a quart of tranny fluid, but Rislone or synthetic oil are much gentler.
Author:  SlantSixDan [ Sun May 03, 2009 9:27 am ]
Use soup if you can get all the ingredients or reasonable substitutes.
Author:  68barracuda [ Tue May 05, 2009 4:37 am ]
Post subject:  update
Did the flush again - pressure (in psi) up less smoke
#1 150
#2 162
#3 140
#4 155
#5 140
#6 150
