8-3/4" rear end axle shims
https://slantsix.org/forum/viewtopic.php?t=35193
Author:  gato [ Mon May 04, 2009 10:42 am ]
Post subject:  8-3/4" rear end axle shims
hi everybody!
i'm replacing the wheel bearings in the rear end of my A108 van.
timing turned out to be perfect and i'm upgrading as well to 11" brakes. in the donor vehicle i found a shim between the passenger side backing plate and the axle housing.
what purpose does this shim serve?
is it relevant if it is on the housing itself, or can it be inside the brake drum area?
D~~~!
Author:  Joshie225 [ Mon May 04, 2009 12:29 pm ]
That should be a coated metal gasket. There should be a metal gasket between each backing plate and the housing. There should be a foam gasket between the axle retainer and the backing plate. Both types can be had through FelPro.
http://slantsix.org/forum/viewtopic.php ... pro#227421
Author:  gato [ Mon May 04, 2009 9:04 pm ]
do u happen to have a part # for those gaskets?
my local parts man tells me there are not available anymore. he also tells me the seal kits used to include the flange that holds the outer seal.
D~~~!
Author:  Joshie225 [ Mon May 04, 2009 9:14 pm ]
Try clicking the very obvious red link.
What year is this housing and axles? The outer seal on a flanged axle is captured between the wheel bearing and the axle flange.
Author:  gato [ Tue May 05, 2009 5:28 am ]
Post subject:  ooops!
so call me Homer and hand me a donut.
i'll run thos #'s by Mr. parts man. .. .
thx
D~~~!
