It is currently Tue Nov 17, 2026 5:09 pm
 Post subject: ordered my clutch
PostPosted: Tue May 05, 2009 3:29 pm
i ordered my clutch today and i got a question
i ordered the 10 inch zoom clutch insted of the 9 1/4 and i was just checking when i get the clutch, wont i have to use the clutch bolts off like an f-body instead of stock becouse of some kind of a clearence issue ro is that somthing i dreamed up?
1973 plymouth duster 225 slant six .30 over, erson 270 cam, 9.5 to 1 compression, big valves, headers, and a holley 4 bbl
http://cardomain.com/ride/3135091
hey that thing got a hemi? naw its just a slant six
PostPosted: Tue May 05, 2009 4:06 pm
Yes, you'll need smaller head diameter bolts to attach the clutch cover to the flywheel.
Is this a stock engine? One that won't rev over 5k RPM at the most? I don't want you to experience a clutch explosion like Greg O did.
http://www.slantsix.org/forum/viewtopic ... 07&start=8
 Post subject: yep
PostPosted: Tue May 05, 2009 5:44 pm
No one wants to go through that! :oops:
PostPosted: Wed May 06, 2009 1:47 pm
like are yall talkin about shifting over 5000 or in high gear turning 5000
this is gonna be my mild street car with compression, cam, intake and head work
PostPosted: Wed May 06, 2009 1:56 pm
I'd have to say that any engine operation above 5000 RPM with the scalloped 10" clutch is questionable.
PostPosted: Wed May 06, 2009 5:31 pm
which if i turn lower rpms it will make my engine last longer 9in the long run right?
PostPosted: Wed May 06, 2009 6:02 pm
Come again?
PostPosted: Thu May 07, 2009 3:42 pm
the 9 wont supposed to be in there. i was asking if i didnt run the engine so hard would it last longer right?
PostPosted: Thu May 07, 2009 4:11 pm
Keep in mind that the Zoom=China :shock: Just be careful wit it :wink:
Users browsing this forum: Amazon [Bot], Bing [Bot] and 2 guests
