How do I shorten my E Brake cable?
https://slantsix.org/forum/viewtopic.php?t=35207
Author:  ppsi [ Mon May 04, 2009 6:16 pm ]
Post subject:  How do I shorten my E Brake cable?
What would be the best way to shorten the e-brake "loop" cable in a 6 Dart. The 8 1/4 rear I just installed had good e-brake cables in the backing plates so I used them and now the cable is too long that connects the two sides. I'd love to swage (spell much?) new balls on one end but don't know how to g about this. Would a simple hardware store wire rope coupling do the job in a reliable/safe manner or should I go about this another way?
Thanks-Howard
Author:  Joshie225 [ Mon May 04, 2009 6:25 pm ]
You don't, not without special tooling at least. Go get the brake cables from your old rear axle and swap them into the 8 1/4.
Author:  sandy in BC [ Mon May 04, 2009 6:28 pm ]
Cable clamps can be used to make a loop in the cable to shorten it.
Author:  ppsi [ Tue May 05, 2009 6:26 am ]
Waaaaaaay too much work at this point. I need an easier fix. the ols cables were in very poor shape and if I was going to go through the trouble of tearing all the brakes off the 8 1/4 that I just put on and tearing off the old cables I'd still feel like I have lousy cables in which case I would forgo the old ones and replace-w-new IF I could find them which is doubtful.
I'm thinking I'll come across something that will allow me to safely shorten the one loop that bridges the rear wheels.
Thanks-Howard
Author:  66aCUDA [ Tue May 05, 2009 6:49 am ]
Howard
Like Sandy says the cable clamps work great. I used 2. That was 15 years ago, the cable finely rusted threw due to Ohio's salted roads.
Frank
Author:  Charrlie_S [ Wed May 06, 2009 4:26 am ]
Thanks-Howard
Rock auto parts. Raybestos part number BC92205 $15.95 ea.
http://www.rockauto.com/catalog/x,carco ... -autoparts
Also available at most part stores. Just because it is for an old car, doesn't mean the part is made of unobtainium
Author:  68barracuda [ Sat May 09, 2009 12:11 am ]
I agree case in point - My 78 CL Regal SE lost its rear wheel cylinders - shopped around on the net very expensive $40 each excluding shipping.... so I decide to have them relined new pistoms ,mmad - wnt to the Brake guys the guy gave it one look turned around and too two of the shelf for ...$40 total - the correct PBR OE part - now how is this possible?.. FORD still use these with their imperial threads on the 2008 model Ford Bantam LDV
Was able to source ALL the brake hardware this way
