| ordered my clutch https://slantsix.org/forum/viewtopic.php?t=35211 |
| Author: | theslantingsix [ Tue May 05, 2009 3:29 pm ] |
| Post subject: | ordered my clutch |
i ordered my clutch today and i got a question i ordered the 10 inch zoom clutch insted of the 9 1/4 and i was just checking when i get the clutch, wont i have to use the clutch bolts off like an f-body instead of stock becouse of some kind of a clearence issue ro is that somthing i dreamed up? |
| Author: | Joshie225 [ Tue May 05, 2009 4:06 pm ] |
Yes, you'll need smaller head diameter bolts to attach the clutch cover to the flywheel. Is this a stock engine? One that won't rev over 5k RPM at the most? I don't want you to experience a clutch explosion like Greg O did. http://www.slantsix.org/forum/viewtopic ... 07&start=8 |
| Author: | Greg Ondayko [ Tue May 05, 2009 5:44 pm ] |
| Post subject: | yep |
No one wants to go through that! Greg |
| Author: | theslantingsix [ Wed May 06, 2009 1:47 pm ] |
like are yall talkin about shifting over 5000 or in high gear turning 5000 this is gonna be my mild street car with compression, cam, intake and head work |
| Author: | Joshie225 [ Wed May 06, 2009 1:56 pm ] |
I'd have to say that any engine operation above 5000 RPM with the scalloped 10" clutch is questionable. |
| Author: | theslantingsix [ Wed May 06, 2009 5:31 pm ] |
which if i turn lower rpms it will make my engine last longer 9in the long run right? |
| Author: | Joshie225 [ Wed May 06, 2009 6:02 pm ] |
Come again? |
| Author: | theslantingsix [ Thu May 07, 2009 3:42 pm ] |
the 9 wont supposed to be in there. i was asking if i didnt run the engine so hard would it last longer right? |
| Author: | 6shotvanner [ Thu May 07, 2009 4:11 pm ] |
Keep in mind that the Zoom=China |
