How to choose/calculate correct leaf spring rate
https://slantsix.org/forum/viewtopic.php?t=35291
Author:  Adrenalin [ Mon May 11, 2009 1:55 am ]
Post subject:  How to choose/calculate correct leaf spring rate
Dear all,
I do own a 1975 Dodge power wagon truck. The ride is really bouncy so I decided to check if the springs are too stiff for my truck (or my shock absorbers are $#!+). There are many spring rate calculators around but I need to determine which spring rate I need which I guess the paremeters should include front weight of my car (unsprung weight), axle+tire weight (spring weight).. etc. Or do i just check it with the static sag of the leaf?
Thanks
Author:  hellion_locdogg [ Tue May 12, 2009 10:10 pm ]
Call a place that re-arches springs, they should know the spring rate(distance between eyes OFF the vehicle+ # of leafs). Depending on how old your shocks are you may just change them, they should not cost much. I just had my car springs re-arched to stock +2" and it made a world of difference. They had helper springs from the previous owner.
Author:  Adrenalin [ Tue May 12, 2009 11:16 pm ]
thanks for the info but all my drive train is modified and swapped so there is no stock parts. I need to figure out which to choose, what to do :)
