It is currently Fri Jun 12, 2026 9:56 pm
 Post subject: oil pan
PostPosted: Sun May 10, 2009 12:59 pm
Does someone have a picture of a slant six oil pan from the bottom for a 63-66 a-body? I have a 65 Dart and the slant 6 is apparently from a 1979 or 80 car and the center link is rubbing into the pan. Should it be that close? Do I have to swap out the oil pan or are my motor mounts bad? Either way, maybe i could simply shim the mounts?
PostPosted: Sun May 10, 2009 1:57 pm
Click here.
 Post subject: early oil pan
PostPosted: Sun May 10, 2009 5:31 pm
I will try denting the one I have in there now. If it works and doesn't leak, then I will use it. If not, then I haven't damaged anything I was going to use and I will simply have to ask Charlie for the correct pan. Right Charlie?
 Post subject: Re: early oil pan
PostPosted: Mon May 11, 2009 5:54 am
Sorry, Rob. I don't have any extra's. I got one from someone a couple of years ago, and a pickup from Doc, for the engine for my Valiant. I have 4 early "A"s and 4 oil pans.
PostPosted: Mon May 11, 2009 11:53 am
Oh that's okay Charlie. (I see how you are) :) I can scroung up one up north if/when I go this summer. I will dent the pan for now.
