| lower control arm https://slantsix.org/forum/viewtopic.php?t=35323 |
| Author: | kman [ Wed May 13, 2009 4:14 pm ] |
| Post subject: | lower control arm |
the bushing to the K frame bolt and Tortion bar is a pain in the ^$$ to get in. Don't have access to any press's. bigger hammer. anybody have any tips. |
| Author: | Joshie225 [ Wed May 13, 2009 6:21 pm ] |
Sounds like you don't have the proper tools which limits you to taking the lower control arm to a shop. I'd ask some local Mopar folks if they can refer you to a front end shop. |
| Author: | vynn3 [ Thu May 14, 2009 5:53 am ] |
| Author: | kman [ Thu May 14, 2009 6:59 am ] |
| Post subject: | Hammer time |
will have to get the lowers to the shop then, thank you. the tool for the uppers is on its way from Mancini racing. |
| Author: | NewSlanter [ Thu May 14, 2009 4:44 pm ] |
You can draw them into place with a piece of ready-rod, a couple of fender washers, nuts and some big wrenches. Just do yourself a favour and put a light smear of grease in the hole before you start. Hope this helps, Nat |
| Author: | Pierre [ Thu May 14, 2009 5:00 pm ] |
Doesn't the service manual say don't use grease? The uppers you don't need a tool, I used a vice and some large sockets. The lowers may be tricky, getting the bushing in the arm is one thing but getting the spindle into the bushing may be tough without a press. |
