| combustion chamber questions https://slantsix.org/forum/viewtopic.php?t=35347 |
| Author: | darrt wells [ Thu May 14, 2009 5:47 pm ] |
| Post subject: | combustion chamber questions |
I have a couple of combustion chamber questions to ask: 1. Last week i cc'd my cylinder head and i ended up with 59cc chambers, is that some what normal for the SL6 combustion chamber to be that much larger than the spec 54cc chamber? 2. I plan to mill the heads approx 0.033" to get back to 54cc size, (so that i will have a CR of 10.25:1 with the k1/Wiseco setup). Will it be safe to use NGK ZFR5N extended tip spark plugs with this combo, or could i be running the risk of the piston hittng the plug? Would i even notice/see any performance difference over using the extended tip as compared to running a regular NGK GR5? Thanks, Owen |
| Author: | sandy in BC [ Thu May 14, 2009 5:55 pm ] |
Quote: is that some what normal for the SL6 combustion chamber to be that much larger than the spec 54cc chamber?
Yes.Quote: Would i even notice/see any performance difference over using the extended tip as compared to running a regular NGK GR5?
We cant know. I suggest trying both. I like the ZFR5N and use it ,,,,,,but I doubt I can quantify my results.
