best upgrade for the (least) money?
https://slantsix.org/forum/viewtopic.php?t=35350
Page 1 of 2
Author:  Andy's GT [ Thu May 14, 2009 7:41 pm ]
Post subject:  best upgrade for the (least) money?
hey guys, one of my friends here in indy just picked up a 64 lincoln continental (suicide doors, pretty good shape) and that was pretty much the last kick for my slant addiction, im planning on going home and bringing the dart back here within the next few weeks, it currently has a 225 from a 74 valiant in it, have already put on a super six w 2.25 exhaust and glasspack, and done the hei ignition, im thinking i would like to do one more little thng, ideally that would up the power and mpg (since ill be driving it across town...) what would be the best investment that way? i have a limited budget, starting my new pt job should cover the extra insurance (have to keep the other insured as i still owe on it) and lower economy (compared to my stratus) what about a cam? i remember an article on here about how to swap it with the engine still in the car, i havent really done much in the way of internal engine stuff besides head gasket, replacing bent push rods and cleaning lifters when i first got it. is a 67 dart gt one of the ones you can swap cams on in car? would a cam be the right way to go? waiting to hear back on insurance for it and gotta look into registration etc as it registered in illinois right now. thanks!
Author:  Reed [ Thu May 14, 2009 8:04 pm ]
You have done the basics. The next cheapest thing i woudl recommend would be to pull the head, CC the chambers, and mill it to increase compression. If that is beyond you right now, a distributor recurve is pretty cheap and easy.
Author:  Andy's GT [ Thu May 14, 2009 8:07 pm ]
that might be a bit much for me, i dont have the resources or knowledge on the head work, not really sure about the dist either, maybe some of the other indy slant guys would :D im getting happy just thinking about driving it again...
Author:  volaredon [ Thu May 14, 2009 8:31 pm ]
Dont your parents still live in IL???? that would keep you from having to re register and swap the title over to Indiana, etc which should save you some$$$$$$ at least for now. Is your car current in IL? You don't need the card they send you in the mail to buy another sticker just the license plate number. but if it's over a month past due, maybe registering it in IN would be cheaper since IL added the extra $20 "gouge tax", for being overdue.
Author:  Andy's GT [ Thu May 14, 2009 8:43 pm ]
my parents are still there, but i havent had it on the road for like 2 years or so :(
Author:  SlantSixDan [ Thu May 14, 2009 9:49 pm ]
What distributor (exactly) are you using? Depending on that answer, you may be able to find a great deal of performance and economy with a distributor re-curve (or a $75 new #3874714 distributor which already has a good curve on it right out of the box).
Even cheaper and easier: tune-up parts and technique suggestions in this thread.
Author:  wvenable [ Fri May 15, 2009 4:44 am ]
Andy, if you need to pull the head and cc, I can help. I can get you some prices on the machine work. Let me know.
Author:  Andy's GT [ Fri May 15, 2009 6:16 am ]
thanks for the link to those things dan, i dont think i have that cap and rotor, but i have done everything else, on that list except maybe thermostat. im running a stock 74 dist with an hei module and accell yellow coil. im searching for the dist recurve info on here now, wvenable i might take you up on that, rough idea on price?
thanks guys
Author:  slantvaliant [ Fri May 15, 2009 6:57 am ]
Post subject:  Re: best upgrade for the (least) money?
hey guys, one of my friends here in indy just picked up a 64 lincoln continental ...
Does it look like this?
Okay, it's now a 2-door (non-suicide), but ...
Back to your regularly scheduled Slant thread ...
Author:  Andy's GT [ Fri May 15, 2009 7:27 am ]
yeah! just like you said though, not a two door, and its white at the moment, think hes going gloss black eventually.
Author:  wvenable [ Fri May 15, 2009 7:33 am ]
I will call and get you a quote this afternoon. Shouldn't be too bad. We could pull the head at my place, the machine shop is a couple of blocks away.
Author:  Andy's GT [ Fri May 15, 2009 7:54 am ]
thanks!
Author:  wvenable [ Fri May 15, 2009 8:51 am ]
Post subject:  Here ya go!
Degrease and magnaflux $25. Mill up to 30 thou $40. Mill up to 100 thousandths $75. Remember to include gaskets in your budget. Also I am almost sure that intake/exhaust bolts will have to be removed before milling. How much you mill will be determined by finding your current static compression ratio - which I can help you with. What is your target compression ratio? 8.5/9 to 1? Did I forget anything guys? Thanks, Wayne.
Author:  Andy's GT [ Fri May 15, 2009 9:18 am ]
thats not too bad, any chance you have the tools and know how to port and polish the head/match the ports to the manifolds? im not very smart about compression, in the words of ricky bobby, 'i want to go fast!' but i also would like decent mpg :lol:
Author:  wvenable [ Fri May 15, 2009 4:12 pm ]
Andy, port work is hand work. Hand crafted. I have watched it done. Have not done it myself. It is much more expensive than milling the head. Set your budget and goals and I will help.
Page 1 of 2 All times are UTC-07:00
