8.25 rear end bolt pattern
https://slantsix.org/forum/viewtopic.php?t=35383
Page 1 of 1
Author:  dakight [ Sun May 17, 2009 11:49 am ]
Post subject:  8.25 rear end bolt pattern
I may have located an 8.25 rear end with a 3.21 ratio. Before I make the trip to get it I want to be sure about the bolt pattern. I don't believe small bolt pattern was ever put in an 8.25 rear but would like to have that confirmed as I need the LBP.
I'm hoping to snag the shock mount plates at the same time but if they aren't there is it difficult to find them?
Author:  Joshie225 [ Sun May 17, 2009 12:03 pm ]
Big bolt pattern for sure. Get the spring/shock plates. U-bolts are the only truly easy part to replace.
Author:  SlantSixDan [ Sun May 17, 2009 2:00 pm ]
Correct, no small-bolt 8¼" rear axles. I don't imagine shock plates should be too tough to find, tho I could be wrong.
Author:  NewSlanter [ Sun May 17, 2009 3:41 pm ]
I don't know about the supply of shock plates in AZ, but when I swapped my 7¼ for an 8¼ They were as rare as hen's teeth. I had to drill out the ones that came with the rear for new shock studs (both were broken off).
Nat
Author:  dakight [ Sun May 17, 2009 4:42 pm ]
Many Dakotas have the 8 1/4 rear axles, perhaps shock plates from those can be made to work. I'll go out and look at mine. What about shock mount plates from a Ford? I believe they use 3" tubes as well. Obviously I will get them with the axle if I can.
EDIT: Well, the Dakota plates won't work; the shock mounts are welded to the axle and the plates are just a simple stand steel saddle with no mounting stud for the shock absorber.
