It is currently Fri Jun 19, 2026 3:45 am
PostPosted: Wed May 20, 2009 4:01 am
Does anyone have a technique that can be done at home using readily available tools to remove the old pistons from the rods?
Failing that, how is this normally done? Press frame? Do you need a special tool to push the pin through the piston/rod?
Does my local auto parts store have the tools to do it?
TIA
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Wed May 20, 2009 4:29 am
to press them apart usually there is no heed payed toward saving the piston so its done in a press, to put them together the small end of the rod is heated up and the wrist pin is slid in and lined up very quickly. to press out you could use a long bolt and a socket to make a puller,I made one for small engines out of bushings
Nick
86 d150 turbo /6.
Users browsing this forum: Amazon [Bot], Google [Bot] and 2 guests
