It is currently Tue May 19, 2026 9:01 pm
 Post subject: Too Much Pulloff
PostPosted: Wed May 20, 2009 8:07 am
I just replaced the choke pull off on my truck because the other one was leaking. Now after i replaced this when i go to start it in the morning i noticed that the pull off automatically completely opens the choke up with out even letting the engine warm up. It has way too much vacuum but i dont no where to begin.
Joe Reusch
1981 Dodge D-150 Slant Sickness
PostPosted: Wed May 20, 2009 8:44 am
You can probably find what you need in the Carburetor operation & repair thread. There are a couple of links for choke adjustment.
Danny
PostPosted: Wed May 20, 2009 10:02 am
You will need to rebend/adjust the linkage per the manual specs. When I replaced mine I had to do the same thing. It is easy to do and works per the spec for your carb.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 12 guests
