Slant Six Forum https://slantsix.org/forum/ |
Too Much Pulloff https://slantsix.org/forum/viewtopic.php?t=35430 |
Author: | 81dodged150 [ Wed May 20, 2009 8:07 am ] |
Post subject: | Too Much Pulloff |
I just replaced the choke pull off on my truck because the other one was leaking. Now after i replaced this when i go to start it in the morning i noticed that the pull off automatically completely opens the choke up with out even letting the engine warm up. It has way too much vacuum but i dont no where to begin. |
Author: | 65Dodge100 [ Wed May 20, 2009 8:44 am ] |
Post subject: | |
You can probably find what you need in the Carburetor operation & repair thread. There are a couple of links for choke adjustment. Danny |
Author: | Aggressive Ted [ Wed May 20, 2009 10:02 am ] |
Post subject: | |
You will need to rebend/adjust the linkage per the manual specs. When I replaced mine I had to do the same thing. It is easy to do and works per the spec for your carb. |
Page 1 of 1 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
