| Oil Pump sensor leaking https://slantsix.org/forum/viewtopic.php?t=35438 |
| Author: | Mister_Perkins [ Wed May 20, 2009 6:44 pm ] |
| Post subject: | Oil Pump sensor leaking |
Does chrysler dodge carry oil pump sensors or do you have to buy the whole pump? My oil pump started leaking at the sensors. Think one of the sensors might be bumm too because I'm getting inaccurate readings. Hooked an oil pressure gauge with a plate adapter under the filter and it was reading differently than what the gauge was reading. 225 slant six 1987 dodge d150 pickup non cali. |
| Author: | SlantSixDan [ Wed May 20, 2009 7:24 pm ] |
Oil pressure sender. Parts store item; try for a Standard or a NAPA Echlin brand sender. You'll also need the special sender socket to attach to your 3/8"-drive socket wrench to remove the old and install the new one. Got those books on the way yet? |
