| The 65 went back on the Dyno https://slantsix.org/forum/viewtopic.php?t=3545 |
| Author: | Trysix [ Tue Apr 30, 2002 10:05 pm ] |
| Post subject: | The 65 went back on the Dyno |
Back in Dec: I had the oprotunity to put the old Hoopy on a friend's dyno. With a 390 holley adapted to a 2bbl intk, and electronic Ignition the 225 put out 97 Rear wheel HP and 153 fp of Torque. After a .030 overbore, clifford intake and headers, Comp264s cam, minor head work, and a homemade windage tray.... This past weekend she ran 137HP at 178fp of torque. I always figured HP is harder to get than the advertised figures of parts manufac.....but I am not disapointed in the results..the old bomb is running great. It would be interesting to know what kind of results others are getting at the rear wheels. I know most people can't afford the Dyno thing...I just have a good friend. Anyway, I promised some of you guys that I would get back ...with the results Trysix Soupitup@msn.com |
| Author: | Doctor Dodge (Doug Dutra) [ Tue Apr 30, 2002 10:36 pm ] |
| Post subject: | Re: The 65 went back on the Dyno |
: Back in Dec: I had the oprotunity to put the : old Hoopy on a friend's dyno. With a 390 : holley adapted to a 2bbl intk, and : electronic Ignition the 225 put out 97 Rear : wheel HP and 153 fp of Torque. : After a .030 overbore, clifford intake and : headers, Comp264s cam, minor head work, and : a homemade windage tray.... : This past weekend she ran 137HP at 178fp of : torque. : I always figured HP is harder to get than the : advertised figures of parts manufac.....but : I am not disapointed in the results..the old : bomb is running great. It would be : interesting to know what kind of results : others are getting at the rear wheels. I : know most people can't afford the Dyno : thing...I just have a good friend. : Anyway, I promised some of you guys that I : would get back ...with the results : Trysix 40 more H.P. at the rear wheels, thats a great improvement. Did you get a chance to try some different timing or carb settings? (My guess is that there are a few more "horses" hiding in there) DD |
| Author: | Mitch [ Wed May 01, 2002 2:52 pm ] |
Depending on the kind of dyno you were using, typical driveline losses are 15-20%. So your crankshaft HP and TQ were in the 171/225 range. Mitch m5black@aol.com |
| Author: | Trysix [ Wed May 01, 2002 5:05 pm ] |
: Depending on the kind of dyno you were using, : typical driveline losses are 15-20%. So your : crankshaft HP and TQ were in the 171/225 : range. : : Mitch The Dyno owner mentioned the 15% thing to me....I just added the 40HP gain to the 145HP original factory advertised rating.....so as to get 185 HP....anyway it's just something to play with... Trysix Soupitup@msn.com |
| Author: | trysix [ Wed May 01, 2002 5:20 pm ] |
: 40 more H.P. at the rear wheels, thats a great : improvement. : Did you get a chance to try some different : timing or carb settings? (My guess is that : there are a few more "horses" : hiding in there) : DD Doc: The only thing that I played with was the rev limits and exhaust. I bumped my rev limit from 5.4 k to 5.6K and the curves stayed relatively flat with a little increase. I also remove the covers from my exhaust cut-outs located just before the mufflers at the rear axle. I only saw about a 2HP increase...if that.It did make a lot more racket though. I agree I feel there is more power in tuning....I still havent tried rejetting the carb and your right it would have been nice to play with the timming a bit. I plan on taking it to the racetrack soon ...maybe I'll find something there. I don't know what to expect from the 1/4 mile performance but I'm not real optimistic this cars a 4dr B body with no fat removed. Trysix Soupitup@msn.com |
| Author: | andrew [ Wed May 01, 2002 6:00 pm ] |
I plan on putting mine on the dyno at the sometime this summer but how knows!!! andrew wagner Quote:
: Back in Dec: I had the oprotunity to put the : old Hoopy on a friend's dyno. With a 390 : holley adapted to a 2bbl intk, and : electronic Ignition the 225 put out 97 Rear : wheel HP and 153 fp of Torque. : After a .030 overbore, clifford intake and : headers, Comp264s cam, minor head work, and : a homemade windage tray.... : This past weekend she ran 137HP at 178fp of : torque. : I always figured HP is harder to get than the : advertised figures of parts manufac.....but : I am not disapointed in the results..the old : bomb is running great. It would be : interesting to know what kind of results : others are getting at the rear wheels. I : know most people can't afford the Dyno : thing...I just have a good friend. : Anyway, I promised some of you guys that I : would get back ...with the results : : Trysix |
