oil pumps
https://slantsix.org/forum/viewtopic.php?t=35457
Page 1 of 1
Author:  mopardemon71 [ Fri May 22, 2009 10:13 am ]
Post subject:  oil pumps
So this topic is not so new but where can I get a high volume oil pump or something that will handle 6500 rpm. I wont go that high but you never know.
Author:  SlantSixDan [ Fri May 22, 2009 11:31 am ]
A high-volume oil pump isn't just unnecessary, it's actually a poorer choice for high-RPM usage, for it greatly increases the load on the pump drive (cam worm/pump pinion).
Author:  vynn3 [ Fri May 22, 2009 12:10 pm ]
Send one to Doug and have him do his "magic" blueprinting. Wish I had...
Author:  Doc [ Fri May 22, 2009 1:57 pm ]
The best choice for a performance SL6 is to use a "medium volume" (7/8 thick impeller) and rework it for more efficency, then add a case hardened drive gear.
I have done many of these "blueprinted" oil pumps over the years so drop me a PM if you need more info.
Author:  mopardemon71 [ Fri May 22, 2009 2:51 pm ]
So why is the m66hv not good. I thought the high pressure pump was the bad one, not the high volume one?
Author:  Doc [ Fri May 22, 2009 5:09 pm ]
The "HV" pump is he 1 inch impeller...
Seeing that the factory pump has a 5/8 thick impeller, the 1 inch is way overkill and more expensive.
Author:  slantzilla [ Fri May 22, 2009 6:22 pm ]
I have a motor in my shop right now with the MP high volume pump on it. Less than 300 miles on the motor and the pump gear is trashed. :shock:
Author:  LWS1967 [ Fri May 22, 2009 6:36 pm ]
I would "assume" (based on what I may or may not know) that too heavy an oil would possibly perhaps have some impact on that? :?
Author:  slantzilla [ Sat May 23, 2009 3:27 am ]
Possibly. This motor had 10-30 in it. :shock:
Author:  Doctor Dodge [ Sat May 23, 2009 8:26 am ]
http://www.slantsix.org/articles/oil-pu ... report.htm
