833 installation
https://slantsix.org/forum/viewtopic.php?t=35458
Author:  red79 [ Fri May 22, 2009 10:37 am ]
Post subject:  833 installation
I just crawled under my volare to investigate an odd, intermittent clank that seemed to be coming from the area around the transmission as well as the difficult gear selection (especially N->1st) that I've been experiencing.
Isn't the tailshaft of the 833 OD supposed to be bolted to the transmission support member? I can literally reach up and slide the driveshaft+tranny about a half an inch in either direction. I've attached a picture of where I suspect a couple of important bolts have worked loose.
Author:  Fopar [ Fri May 22, 2009 12:07 pm ]
That would be the rear mount missing :shock:
Author:  red79 [ Fri May 22, 2009 12:16 pm ]
well fortunately the mount is there, there are just no bolts connecting them together :shock: time to get out the box of spares
Author:  DusterIdiot [ Fri May 22, 2009 7:08 pm ]
Post subject:  Yep...
I have been finding with the Hpak duster it has enough torque that it will hammer the mount and I have lost the bolts at one point in time (the car feels like the clutch is going out/spongy)...I now loc-tite those bolts, but I noticed I might have to redrill/thread the bolt holes as the hammering 'waddles' out the aluminum and the bolts no longer grip right...
Author:  red79 [ Sat May 23, 2009 12:40 am ]
Thanks for the tips--the clutch had been getting chattery over the past few months, and replacing the missing anchor bolts has solved that, the shifting problems, and that disturbing clank :D I wonder how long they've been missing...
Author:  Charrlie_S [ Sat May 23, 2009 4:34 am ]
Whenever I build a trans for a non-stock MOPAR, I install "helicoils" in those holes. Also, if an auto trans, with a floor shifer conversion that bolts the bracket to the pan bolts, they get helicoils.
