It is currently Mon Jun 15, 2026 3:52 pm
 Post subject: oil pumps
PostPosted: Fri May 22, 2009 10:13 am
So this topic is not so new but where can I get a high volume oil pump or something that will handle 6500 rpm. I wont go that high but you never know.
it's like a vw, sounds like a million miles an hour but goes really slow. (for now)
PostPosted: Fri May 22, 2009 11:31 am
A high-volume oil pump isn't just unnecessary, it's actually a poorer choice for high-RPM usage, for it greatly increases the load on the pump drive (cam worm/pump pinion).
PostPosted: Fri May 22, 2009 12:10 pm
Send one to Doug and have him do his "magic" blueprinting. Wish I had...
vm
PostPosted: Fri May 22, 2009 1:57 pm
The best choice for a performance SL6 is to use a "medium volume" (7/8 thick impeller) and rework it for more efficency, then add a case hardened drive gear.
I have done many of these "blueprinted" oil pumps over the years so drop me a PM if you need more info.
PostPosted: Fri May 22, 2009 2:51 pm
So why is the m66hv not good. I thought the high pressure pump was the bad one, not the high volume one?
PostPosted: Fri May 22, 2009 5:09 pm
The "HV" pump is he 1 inch impeller...
Seeing that the factory pump has a 5/8 thick impeller, the 1 inch is way overkill and more expensive.
PostPosted: Fri May 22, 2009 6:22 pm
I have a motor in my shop right now with the MP high volume pump on it. Less than 300 miles on the motor and the pump gear is trashed. :shock:
PostPosted: Fri May 22, 2009 6:36 pm
I would "assume" (based on what I may or may not know) that too heavy an oil would possibly perhaps have some impact on that? :?
PostPosted: Sat May 23, 2009 3:27 am
Possibly. This motor had 10-30 in it. :shock:
PostPosted: Sat May 23, 2009 8:26 am
http://www.slantsix.org/articles/oil-pu ... report.htm
Users browsing this forum: Ahrefs [Bot] and 4 guests
