Exhaust manifold question
https://slantsix.org/forum/viewtopic.php?t=3549
Page 1 of 1
Author:  Warren Puziewicz [ Wed May 01, 2002 3:31 pm ]
Post subject:  Exhaust manifold question
Hi,
My 67 Dart convertible has a cracked exhaust manifold and I need some help. I've called around looking for a replacement, and the going price seems to be over $100. I've got an old Super Six setup (from a 79 Volare), but no carb for it. I'm wondering if I can use the exhaust from the Super Six with the original intake. I know the Super Six intake might give me a little more power, but then I'd have to find a carb, air cleaner and kickdown linkage. The weather's getting nice and I really want to get this car back on the road ASAP without having to breath exhaust fumes.
Thanks
puzmail@mn.rr.com
Author:  Doctor Dodge (Doug Dutra) [ Wed May 01, 2002 7:42 pm ]
Post subject:  Re: Exhaust manifold question
: Hi,
: My 67 Dart convertible has a cracked exhaust
: manifold and I need some help. I've called
: around looking for a replacement, and the
: going price seems to be over $100. I've got
: an old Super Six setup (from a 79 Volare),
: but no carb for it. I'm wondering if I can
: use the exhaust from the Super Six with the
: original intake. I know the Super Six intake
: might give me a little more power, but then
: I'd have to find a carb, air cleaner and
: kickdown linkage. The weather's getting nice
: and I really want to get this car back on
: the road ASAP without having to breath
: exhaust fumes.
The supersix exhaust manifold will interchange *if* it is not badly worped.
(worped ones are hard to mate with a different intake)
Another challenge is getting everything apart without breaking bolts or studs, start soaking everything with "liquid wrench" or other lub. ASAP.
If a bolt / nut does not come loose easily, apply heat.
Author:  Warren P [ Wed May 01, 2002 9:32 pm ]
Thanks, that's what I was hoping to hear.
: The supersix exhaust manifold will interchange
: *if* it is not badly worped.
: (worped ones are hard to mate with a different
: intake)
: Another challenge is getting everything apart
: without breaking bolts or studs, start
: soaking everything with "liquid
: wrench" or other lub. ASAP.
: If a bolt / nut does not come loose easily,
: apply heat.
: DD
puzmail@mn.rr.com
Author:  63gtcvred [ Sat Nov 17, 2018 7:35 pm ]
Carbs are not hard to find and kick down ain't that hard either.
Seat of the pants between a 1 and 2 bbl. will make you happy.
If not able to do swap right now....cast iron can be welded.
Author:  63gtcvred [ Sat Nov 17, 2018 7:36 pm ]
Damn....this is an OLD POST....sorry
