It is currently Sat Jun 06, 2026 2:51 am
 Post subject: Wheel well roll
PostPosted: Sun May 24, 2009 7:27 am
Not sure where to post this but has anyone tried to roll the rear wells out with pipes on the wheels or something like that? I have only heard of it but never attempted myself. I only need about an inch wider. Thanks for the help
PostPosted: Sun May 24, 2009 8:57 am
Car Model: 63 Dart 81 D150
I tried that on my Dart, but the area was rusty and it did not work so well, so I used a cut off wheel to gain my clearance.
It takes 2 people, 1 to drive the car back and forth, and 1 to work the pipe. I would be real careful if it is a good looking car, it is REALLY EASY to destroy a good quarter panel. I did not care on my car, as rust had already destroyed my quarters before I got it.
TopHat
 Post subject: massaging rear wheel lip
PostPosted: Sun May 24, 2009 10:51 am
I used a wooden baseball bat and had a couple of guys push the car back and forth and had to do it about a dozen times per side (car wasn't running). It worked, but I did it a little at a time and before car was painted. Cutoff wheel might work, but it weakens the wheel lip if someone were to lean against that area. Maybe try it on a beater car first for practice.
PostPosted: Sun May 24, 2009 6:01 pm
Don't have a pic, but I just cut the wheel opening bigger, no more lips. They were rusty anyway. I had 245-60-15 tires and it was plenty strong to cut up the sidewalls that were sticking out. I am fairly sure patch panels would fix it if I ever wanted to.
TopHat
Users browsing this forum: Amazon [Bot] and 2 guests
