| Let the grinding begin. Cut Aussie intake. https://slantsix.org/forum/viewtopic.php?t=35504 |
Page 1 of 2 |
| Author: | Rust collector [ Mon May 25, 2009 5:54 am ] |
| Author: | Doctor Dodge [ Mon May 25, 2009 6:34 am ] |
Now there is something you don't see everyday... Looks like about 1/16th of core shift on that manifold. (the top wall is thicker then the floor) The good news is that the shift is even all the way across. Fire-up the TIG and start welding!! DD |
| Author: | Wizard [ Mon May 25, 2009 6:58 am ] |
| Post subject: | yow! Scrailge! |
yikes!! Running for the hill. Have you ever heard of ultrasonic measuring for thickness? BTW, this is most beauiful castings I ever seen. Cheers, Wizard |
| Author: | LWS1967 [ Mon May 25, 2009 8:02 am ] |
What was it that got you sooooo angry at it that you had to cut the sucker up?!!!!! Poor thing...... |
| Author: | stonethk [ Mon May 25, 2009 8:22 am ] |
Never question a mad genius |
| Author: | wvenable [ Mon May 25, 2009 9:40 am ] |
Did the Aussie dudes hire you as quality control? |
| Author: | Shaker223 [ Mon May 25, 2009 3:33 pm ] |
Quote: What was it that got you sooooo angry at it that you had to cut the sucker up?!!!!! Poor thing......
It knew it had it coming.
| Author: | Mister_Perkins [ Mon May 25, 2009 3:50 pm ] |
very cool turbo setup. You could probably sell those for a decent price |
| Author: | Wizard [ Tue May 26, 2009 8:37 pm ] |
What the reason? In porting, you DO NOT want it to widen sudden (that slows the air flow) out especially in that area and just taper out 2" into from the flanges where it meets head. and leave the manifold ports slightly SMALLER than the head ports to keep air from bouncing back out. Same on exhaust. But this time, ports on the head is slightly smaller than the exhaust manifold. Cheers, Wizard |
| Author: | ceej [ Tue May 26, 2009 8:50 pm ] |
Building for Twins? CJ |
| Author: | Shaker223 [ Wed May 27, 2009 5:48 am ] |
Quote: What the reason?
The reason is the stock configuration probably would not support 25 pounds of boost efficiently. The runners would be a restriction.
| Author: | Wizard [ Wed May 27, 2009 6:40 am ] |
These manifold flows rather well and most uniformly distributed and that is the major reason as evidenced with Doc's hurricane manifold had him surprised barking the tires too easily vs regular super six and his hyper manifolds. Just turbo the slant with unmodified hurricane as is and see. Cheers, Wizard |
| Author: | Shaker223 [ Wed May 27, 2009 7:45 am ] |
Well, it's to late to see besides this is for the new engine. I have a ported Clifford (std length) on the slant now and it runs 12.30's. I should be able to get the stocker into the 11s with a real good launch and a touch more psi. |
| Page 1 of 2 | All times are UTC-08:00 |
