| flex fan https://slantsix.org/forum/viewtopic.php?t=3551 |
| Author: | el vez [ Thu May 02, 2002 4:38 am ] |
| Post subject: | flex fan |
whats a good fan to augment the cooling on my 198ci ssix in my 73 swinger? converted to 134a and really can tell a difference in cooling at idle. is there any thing mopar specific i need to know when i go fan shopping? im here in san antonio so this is a big deal. thanks ptgc@idworld.net |
| Author: | Trysix [ Thu May 02, 2002 6:24 pm ] |
| Post subject: | Re: flex fan |
: whats a good fan to augment the cooling on my : 198ci ssix in my 73 swinger? converted to : 134a and really can tell a difference in : cooling at idle. is there any thing mopar : specific i need to know when i go fan : shopping? im here in san antonio so this is : a big deal. : thanks El Vez, If you haven't already, get and use a good raiator flush. If your radiator is really dirty get it roded out at a reliable radiator shop. Also replace the thermostat...don't use the regular cheap thermostat...get a Stant Superstat they are much better for a couple of bucks difference. I've used standard stainless flex fans and the smaller lighter aluminum version. (which I'm using now) They both perform well but I prefer the lighter Aluminum with a medium pitch. Flex fans are pretty universal. Try to match the dia. to your rad core/shroud. Measure everything and maintain about 1 inch clearence from radiator and anything else that's close to the fan.Different size spacers are available to get it spaced in relation to rad. core. I like em. Trysix Soupitup@msn.com |
| Author: | el vez [ Fri May 03, 2002 4:14 am ] |
Thanks Trysix, its always the simple stuff i forget to do first. i think its cause i want a shiny new stuff under the hood! Quote:
: : El Vez, : : If you haven't already, get and use a good : raiator flush. If your radiator is really : dirty get it roded out at a reliable : radiator shop. : Also replace the thermostat...don't use the : regular cheap thermostat...get a Stant : Superstat they are much better for a couple : of bucks difference. : I've used standard stainless flex fans and the : smaller lighter aluminum version. (which I'm : using now) They both perform well but I : prefer the lighter Aluminum with a medium : pitch. Flex fans are pretty universal. Try : to match the dia. to your rad core/shroud. : Measure everything and maintain about 1 inch : clearence from radiator and anything else : that's close to the fan.Different size : spacers are available to get it spaced in : relation to rad. core. : I like em. : : Trysix ptgc@idworld.net |
