slant six gaskets cork or high temp rubber?? wats beta
https://slantsix.org/forum/viewtopic.php?t=35602
Author:  barbski [ Sun May 31, 2009 5:41 am ]
Post subject:  slant six gaskets cork or high temp rubber?? wats beta
what should i use for my slant six rocket cover gasket cork high temp rubber or something else help i been bye mates but i want someone who knows wat there on about to help it was a cork one when i took it off
Author:  slantfin [ Sun May 31, 2009 6:21 am ]
e.e. cummings?
Author:  slantzilla [ Sun May 31, 2009 6:47 am ]
either one will work well if the valve cover flange is flat and you do not tighten the crap out of the mounting bolts
Author:  SlantSixDan [ Sun May 31, 2009 9:12 am ]
I prefer the rubber ones.
Author:  emsvitil [ Sun May 31, 2009 4:52 pm ]
I use the rubber ones and some white grease........
Can reuse that way.
:wink:
Author:  00spy [ Sun May 31, 2009 5:17 pm ]
e.e. cummings?
Dave
Author:  Aggressive Ted [ Sun May 31, 2009 9:04 pm ]
I prefer the rubber over cork. They last alot longer and will reseal after a few valve re-lashing sessions.
Author:  HardCharger [ Sun May 31, 2009 9:39 pm ]
Is that so even when you don't use white grease on them as well?
I did some research and bought the rubber gasket over the cork however I didn't use anything on my rubber gasket after I did my valves last week... :shrug:
Author:  Aggressive Ted [ Sun May 31, 2009 9:43 pm ]
I use just a little synthetic oil and the seat fine. Grease would work just as well.
Author:  emsvitil [ Sun May 31, 2009 10:32 pm ]
Grease or oil is fine.
Dry they might stick...........
Author:  66aCUDA [ Mon Jun 01, 2009 5:35 am ]
Hard Charger you will be fine as long as you go ahead and take it back of an lube it now. It may or may not work if you wait 6 months.
Frank
Author:  zorg [ Mon Jun 01, 2009 8:40 pm ]
I have reused a rubber gasket many times over without any lube. Maybe I just got lucky? Looked in good shape every time it came off, so it just went back on.
Author:  Dart270 [ Tue Jun 02, 2009 7:05 am ]
I don't use any oil/grease and they reuse fine.
Author:  paul_sak [ Tue Jun 02, 2009 6:57 pm ]
Post subject:  Brand?
Is there a preferred brand? The last one I used was a "CORTECO" from the NAPA store and the tabs were off a little bit. Not so far off I got the wrong part but like the mould or die was off a little bit. (Off far enough that only two of the four tabs lined up making installation a bit of a challenge.)
Author:  emsvitil [ Tue Jun 02, 2009 9:12 pm ]
I use the felpro one....
look number up on rockauto.
