| head chamber volume https://slantsix.org/forum/viewtopic.php?t=3563 |
| Author: | dartdude1968 [ Sat May 04, 2002 1:08 pm ] |
| Post subject: | head chamber volume |
What would you guys estimate the cc's to be for the head chamber volume on a stock head for a 225 six? |
| Author: | Will [ Sat May 04, 2002 2:13 pm ] |
| Post subject: | Re: head chamber volume |
: What would you guys estimate the cc's to be for : the head chamber volume on a stock head for : a 225 six? look here Will Posted By: Doctor Dodge (Doug Dutra) Date: Wednesday, 7 November 2001, at 10:47 p.m. In Response To: Shaved head cc's (Tom) : : Just wondering if anyone has cut a head .100 : and cc'd it. I haven't measured mine yet, : but was curious what kind of numbers people : had gotten. Also, is there much difference : in combustion chamber size for different : years? : Thanks, Tom All the SL6 heads are about the same chamber size which is called-out at 54 CCs, In "real life" they run a bit more then that. (55 to as much as 60) I feel that a lot of the difference is based on the type of valve used. (dished vs flat face and how deep the seat is) The last SL6 head I milled .100 and put large "flat faced" O/S valves into, ended-up at 39 CCs. ( I kept the valves up high in the chamber for the best flow ) DD More Info. on SL6 Head Milling & CCs Password: Messages In This Thread Shaved head cc's (views: 56) Tom -- Tuesday, 6 November 2001, at 8:16 p.m. Re: Milled SL6 head cc's (views: 52) Doctor Dodge (Doug Dutra) -- Wednesday, 7 November 2001, at 10:47 p.m. Re: Shaved head cc's (views: 49) Will -- Wednesday, 7 November 2001, at 12:19 a.m. Re: Shaved head cc's (views: 58) Dart270 -- Tuesday, 6 November 2001, at 8:19 p.m. View Thread | Post Response | Return to Index | Read Prev Msg | Read Next Msg Slant Six Forum is maintained by Chuck Rivers with WebBBS 4.33. slantsix@netzero.net |
| Author: | mike [ Sat May 04, 2002 2:14 pm ] |
: What would you guys estimate the cc's to be for : the head chamber volume on a stock head for : a 225 six? NHRA list 2 different cc. later model are listed at 54. although real heads untouched are around 60 to 63 scooterthedog@hotmail.com |
| Author: | slantsix64 [ Thu Apr 04, 2019 5:28 pm ] |
Your going to have to cc the heads pretty simple to do, Get a cd case use the cover, make to holes one to fill and one for air, use vasoline to seal it around the chamber, buy a cc syringe use coolant to fill the chamber up see how many ccs you have them start milling from there. But if your heads are stock .100 cut will wake your motor up, depending on your year block and how low the piston is at at tdc. Mine is a cast crank 50 pounds lighter than other years, it's a 1979 block piston was .140 in the hole, you can measure the piston height buy using feeling gauges stacked up. with a cut of .100 i went from 7:8 CR to 9.1C:R I run 91 octane California. Compression ratio with differ from year to years , but it's safe to say if your head is stock .100 cut will up CR gain power and mileage and you will be able to use stock push rods. |
| Author: | GregCon [ Thu Apr 04, 2019 7:19 pm ] |
I milled my head .070" and wound up at 47.5cc |
| Author: | drgonzo [ Thu Apr 04, 2019 7:49 pm ] |
Quote: I milled my head .070" and wound up at 47.5cc So your chambers must have started around 58cc.+-
| Author: | GregCon [ Fri Apr 05, 2019 4:43 am ] |
Musta been. Of course, the exh valves were badly sunk so that further lowered volume. In addition to milling, the new valves and seats also helped reduce the volume. All I know is I am right at 9.0:1 CR now which will allow my 225 to scream with an untold fury. |
