It is currently Fri Aug 28, 2026 10:50 pm
PostPosted: Fri Feb 08, 2013 10:18 am
I first came across this site a couple of weeks ago. I bought a 63 Valiant just after xmas as I wanted a project to keep me occupied since I recently sold my business to be a full-time stay home dad.
I have had old Falcons in the past but never anything Mopar.
Over here in NZ, old Falcons hold much greater value, so instead of buying a basket-case Ford, for the same sort of money I was able to afford this car, which is a 2 owner car, done 96,000 miles, has been stored in a garage for the past 15 years, has had quite a bit of work done in recent years to get it ready for getting back on the road, but just needed someone to give it some love and finish it off.
Main problems initially were it running hot, and it wont idle once it comes off the auto-choke. Thats when I found this site. Heaps of good info on here, particularly about the Holley 1920, so with any luck next week I will have it running ok and go to try and get it road-legal. Have been concentrating all my efforts so far on the engine, the body is in original paint and has very little rust, so I plan on leaving that for now.
I cant work out how to post pictures here, so I will put a link to some facebook ones. Hopefully you can see it.
[/img]http://www.facebook.com/#!/photo.php?fbid=599026076791190&set=a.599025556791242.153485.100000514103134&type=3&theater[/img]
63 Valiant AP5, 225, 3sp
PostPosted: Fri Feb 08, 2013 3:09 pm
Welcome aboard Dented!
Posting photos requires one to use a photo posting on a free site such as “Photbucketâ€￾dot com that I use. Just open an account, up load your photos to the site, and post the hot link on your post at slant six dot org. Look [url=http://slantsix.org/forum/viewtopic.php?t=4434]here[[/url] for instructions. Red text is a hot link, just click on it and the article will pop up.
Bill from the other side of the world…
PostPosted: Sat Feb 09, 2013 11:33 pm
Sounds like a good buy Dented,AP5's are my favourite. 8)
Another AP5 valiant still going strong.
PostPosted: Sat Feb 09, 2013 11:37 pm
Some pics of mine,i use photobucket and it's easy once you get used to it. :roll: http://slantsix.org/forum/viewtopic.php?t=50638.
PostPosted: Sun Feb 10, 2013 2:50 pm
Yours looks great. I had a crack at loading stuff on photobucket last night, but either the site had a problem or it was me :roll:
I like the rear screen louvre on yours, I would dearly love to get an exterior fron screen visor for mine, havent looked seriously for one yet, but parts seem thin on the ground over on this side of the ditch.
Hopefully I will have the pictures sorted in the next few days
PostPosted: Sat Feb 23, 2013 11:16 pm
A great day today!
When I purchased this car a couple of months ago, the guy said it had 2 problems, it ran too hot, and it wouldnt idle when it was hot. He said it had had a new carburettor fitted too. The over heating was a combination of things that ultimately was easily sorted. But since I have had it running again I havent been able to get it idling hot. It runs the Holley 1920, and I have had it off, in bits, blown it out with compressed air and carb cleaner, rekitted it and checked every adjustment on it, no difference. Checked and rechecked valve lash, timing, and basically eliminated every other thing.
Last week I found a guy selling a Carter off his old Valiant (same model as mine). Bolted it on this morning and the car is instantly fixed. Runs and idles like a dream. Went for a family cruise in it this afternoon and it was smiles all round. I can only assume there must be something fundamentally wrong with the Holley on it, I wonder if it has had the idle misture screw wound in too far at some point and its done some damage to the idle system or the body of the carb. Guess I will never know.
Anyways, I love my car a lot now.
PostPosted: Sat Mar 09, 2013 8:47 pm
Good to hear it's sorted out,i've been running a Carter bbs for awhile now with no dramas at all.
PostPosted: Sun Mar 10, 2013 7:34 pm
Hey I will try and link in some pictures of my car here from another forum.
http://www.nzmoparforum.co.nz/index.php ... 2172;image
http://www.nzmoparforum.co.nz/index.php ... 2173;image
http://www.nzmoparforum.co.nz/index.php ... 2174;image
http://www.nzmoparforum.co.nz/index.php ... 2175;image
PostPosted: Mon Mar 11, 2013 10:17 am
Looks like only members of that forum can see the photos.
1967 Dodge A-100 90 inch wheelbase panel van with a 225 /6 three on the tree Holley 1920 carb
PostPosted: Mon Mar 11, 2013 11:16 am
Thats a bummer
PostPosted: Mon Mar 11, 2013 2:24 pm
A very common cause of poor idle after the engine is warmed up is that the valve lash is too tight. Adjust the lash and see if the idle gets better.
PostPosted: Mon Mar 11, 2013 3:50 pm
Thanks Lou, yeah I fixed the idle, went perfect after I put another carb on it.
