| Holley 450 without ported vacuum https://slantsix.org/forum/viewtopic.php?t=35649 |
| Author: | 67Dart4door [ Tue Jun 02, 2009 10:18 am ] |
| Post subject: | Holley 450 without ported vacuum |
I just installed a Holley 450 4barrel carb on my slant. The carb does not have a ported vacuum port on it for my vacuum advance distributor. Do I need to change my distributor to a mechanical advance dizzy? Or can I just recurve my dizzy and run without the vacuum advance? |
| Author: | Joshie225 [ Tue Jun 02, 2009 10:21 am ] |
For best economy and engine life you need a carburetor with the vacuum advance provision. Sounds like you got one of the cheap street tunnel ram carbs. |
| Author: | 67Dart4door [ Tue Jun 02, 2009 10:43 am ] |
Ya it was a cheap rebuilt carb from www.carburetorsandmore.com I dont really care about economy. Im just messing around with my slant to try to get as much hp out of it and the cool factor. Should I just get a different dizzy? and which one? |
| Author: | Joshie225 [ Tue Jun 02, 2009 10:52 am ] |
A recurved stock electronic distributor is all you need. Use the search function to learn about advance curves. |
