It is currently Thu Nov 12, 2026 12:17 am
PostPosted: Tue Feb 24, 2009 2:21 pm
Here is what I have come up with so far .I have made the HEI conversion with an electric dizzy , a holley 1920, and I am using a relay .I wanted to keep my original air cleaner , and make it look all original for state inspection. here are the pictures of what I have done to make it look like the lean burn system.
I put some new heat insulation on the bottom.
I cut out the innards of the vacuum diaphram.
I drilled out holes for the wire , so it would not be too much pressure on the blades of the module.
Do you think it code pass ?
I will post some more pictures when I put it back on . Hopefully soon.
The module will be grounded to the alternator ground.
Dave
81 Dodge D150
It looked easier in the book .
PostPosted: Tue Feb 24, 2009 2:44 pm
:lol: You sly dog. I like it! You may want to put some kind of strain relief on the wires to prevent any sudden tension on the wires from unlugging the connectors on the module or damaging the module.
PostPosted: Tue Feb 24, 2009 3:27 pm
The fun part was getting the circuit board out :shock: .
I am going to run the wires and secure them the way the other wires were run.
81 Dodge D150
PostPosted: Tue Feb 24, 2009 4:20 pm
Spy Craft....everyday. A lot of Iowa DoT guys are ex KGB
You realize of course that when they do the Big Takedown they will find you out?
PostPosted: Wed Feb 25, 2009 3:39 pm
How many people actually know what a lean burn is supposed to look like anyway?
Be careful, environmentalists can get violent, if they find out... :wink:
'74 Duster 225 Super Six w/904
14" Cragar SS wheels
PostPosted: Wed Feb 25, 2009 3:41 pm
They will never take me alive!!!!!!!!!
81 Dodge D150
PostPosted: Sun Mar 08, 2009 12:59 pm
Well I finally put it back on , and this is how it turned out
I split the distributor wires off from the others
These are the bullet connectors i used to connect the wires ,so if the module croaks, I can use a pe-made spare module ,and connect it without having to take everything apart to make it home.
I have also used a slightly bigger wire loom, to cover where the wires are connected at.
81 Dodge D150
PostPosted: Sun Mar 08, 2009 1:04 pm
Nice! Very stealthy.
PostPosted: Sun Mar 08, 2009 1:17 pm
Excellent spykraft! Have any flamethrowers or cool stuff like that?
(tail light on/off switch) Aircraft landing lights behind the grille? Mariachi horn!
Just make sure you stay on the dark side.
PostPosted: Thu Jun 04, 2009 9:54 am
What did you do with all the wires that went to the computer. I have an 84 d-100 i want to do lean burn on and was just wondering.
