T5 Slanters Needed
https://slantsix.org/forum/viewtopic.php?t=35675
Page 1 of 2
Author:  raPoM [ Wed Jun 03, 2009 10:23 pm ]
Post subject:  T5 Slanters Needed
Since Exner Geek is selling me the modified Bellhousing for the T5(My vote for Man of the year :D ) I need info on what everyone is running as far as clutch,PP,linkage...etc...wit their T5 slants.Any tips greatly appreciated.
My plan is to go yarding for a T5 out of a fox body stang,and one out of a late 80's early 90's chubby s-10.I will then swap the talishaft off the s-10 trans onto the mustang trans for the better shifter location. What I have found: The TKO-600 that Keisler sells for A bodys measures 12.68" from front of case to front of shifter.The s10 is 11.74".
Since the TKO-600 puts the shifter in the perfect spot to run the factory automatic console modified for the shifter,I should be in pretty good shape.May have to move the console up about an inch,but that would be no big deal.
I have been talking with a guy on moparchat who swapped the s-10 trans into his SB A body.He says it was almost a bolt in deal,and should provide near perfect placement for the shifter with the console.He will be sending me pictures of where the shifter pops through.He also used the stock s10 hydraulic clutch master cyl,which he said was also almost a bolt in deal.I am keeping my fingers crossed! I have to have a 5 speed,and I have to keep my stock console,so I hope it will work out.If not I may have to sneak into keisler at night and liberate a trans for my Dart. :twisted:
Thanks
Author:  Dart270 [ Thu Jun 04, 2009 3:40 am ]
raPoM,
Please use the search function on this site. There is a lot of info on T5 and related swaps. Last posts were maybe a year ago.
Author:  raPoM [ Thu Jun 04, 2009 3:06 pm ]
Have any links Lou? I keep getting: "error could not obtain any post".Or something like that. :?
Author:  raPoM [ Sun Jun 07, 2009 1:52 pm ]
Does anyone have any links? The search engine on this site will not work for me. I even put in 'slant six' and nothing came up??? :?
I figured you five speed guys wouldnt mind striking up a disscussion...
Author:  raPoM [ Sun Jun 07, 2009 1:55 pm ]
Ok the guy on moparchat sent me this picture.Its of a s10 T5 mounted in a 68 valiant:
He says he thinks its perfect,he really likes the shifter location. I am thinking I may be able to use the stock console if I move it up about 2 inches and cut a slightly larger hole for the shifter to pop through(larger than the factory 4 speed hole that is).What say you?
Author:  sandy in BC [ Sun Jun 07, 2009 3:28 pm ]
The Mustang shifter is much further back
Author:  sandy in BC [ Sun Jun 07, 2009 3:30 pm ]
We discussed this to death years ago.....
There has even been a group buy.
Search is your friend
Author:  raPoM [ Sun Jun 07, 2009 3:52 pm ]
I am aware of the group buy,hence the reson I am getting the BH from exner geek.
If you would read my post you will see I can not get the search to pull anything up for me not even the words slant six.I also just got a pm from another member who has the same problem with the search function regarding T5 swaps.
Author:  sandy in BC [ Mon Jun 08, 2009 5:14 am ]
By typing T5 in the search box in the trans and rearend section I got 86 replies.
Here is just one http://www.slantsix.org/forum/viewtopic ... ghlight=t5
Author:  raPoM [ Mon Jun 08, 2009 7:16 am ]
Thanks for the link :D Still cant get it to work. must be my software :?
Author:  Dart270 [ Mon Jun 08, 2009 7:38 am ]
You just click on the "Search" button at the upper right of this forum page, then type in "T5". Your computer's software should have nothing to do with this site.
Author:  raPoM [ Mon Jun 08, 2009 12:16 pm ]
Then I do not know what the problem is. I am not retarded,I know how to click the search button.Every time I put anything in the search box,I get an error message.You guys can stop telling me to search,its not working.I have put in every term I can think of slant six related(and some not) and still the same thing.
I would not just throw up some random post asking for info readily availible,I always do my research.
Author:  Joshie225 [ Mon Jun 08, 2009 12:43 pm ]
Two results for my search "T5 swap bellhousing".
http://slantsix.org/forum/viewtopic.php?p=79818
http://slantsix.org/forum/viewtopic.php?p=86838
I would try clearing your browser cache and cookies and trying the search again.
Author:  Dart270 [ Mon Jun 08, 2009 1:40 pm ]
OK, yep, could be browser cache or some such. Sorry if I sounded accusatory...
The 2nd one Josh posted has a bunch of other links inside it.
Author:  raPoM [ Mon Jun 08, 2009 1:53 pm ]
Thanks for the links :D
Lou-No worries! I was starting to get fed up with that search function.I will try to clear my browser and cookies.....
Page 1 of 2 All times are UTC-08:00
