Engine to trans adapter?
https://slantsix.org/forum/viewtopic.php?t=35681
Author:  six popper [ Thu Jun 04, 2009 8:15 am ]
Post subject:  Engine to trans adapter?
I had almost forgoten about this. I purchased a 65 A-100 van sometime back, it had a adapter to put a 727 behind a /6. I was wandering if anyone else had seen one of these. I thought it would be beneficial in being able to put one of the newer 727 based overdrives behind my 225.
Author:  Joshie225 [ Thu Jun 04, 2009 9:13 am ]
Yep, had one myself. You can use the adapter to put just about any small block bellhousing behind the slant. I'd use a smaller, lighter A500 before the A518. Dart270 (Lou) has an A500 in one of his cars.
Author:  slantzilla [ Thu Jun 04, 2009 2:20 pm ]
I have 2 different aftermarket versions of the plate. :shock:
Author:  six popper [ Thu Jun 04, 2009 3:58 pm ]
So if I were to machine the crank spacer for a pilot bearing could I use it to adapt a manual trans. The reason I ask is my truck is a 833 overdrive truck and it would be nice to put a five speed in it.
Author:  Joshie225 [ Thu Jun 04, 2009 5:45 pm ]
Sure. Is your hub spacer small register or large?
Author:  six popper [ Thu Jun 04, 2009 6:15 pm ]
If I remember correctly it is large.
Author:  LWS1967 [ Thu Jun 04, 2009 7:48 pm ]
I've got a 67 A100 with the same setup. It does give you some options, don't know about a manual swap though.
