It is currently Wed Nov 25, 2026 5:35 am
 Post subject: Timing Tab
PostPosted: Sat Jun 06, 2009 10:47 am
I have a 1978 225 /6 in my 1935 Dodge. I moved the alternator to the manifold side, but the little upright tube on the timing tab hits my fan belt. What is the purpose of that tube, and can I remove it?
Thanks,
John
 Post subject: Yep...
PostPosted: Sat Jun 06, 2009 11:19 am
Yep you can remove it, you're using a timing light to do your timing, the factory used a probe that inserted into the tube....quick work with a dremel tool would excise the offending part.
 Post subject: Re: Timing Tab
PostPosted: Sat Jun 06, 2009 12:34 pm
Thanks,
John
That sounds like a great ride/engine combo. 8)
Welcome to the forum!
74 Dodge Charger 225 factory A/C auto 1920 carb stock exhaust.
Mods;
HEI, MSD B3, Magnecor 8 mm, ZFR5N, .060 rotor, CH410X cap, new 3874814 dist, fuel mod, valves hot .010 & .020, all new hoses, JP chain, brake hoses and fluid.
PostPosted: Sat Jun 06, 2009 12:57 pm
Thanks so much for the rapid response! Dremel tool is already spinning up to speed.
John
