It is currently Wed May 13, 2026 12:11 pm
 Post subject: 3/8ths vs 5/16ths line?
PostPosted: Sun Jun 07, 2009 3:18 pm
Car Model: 1967 Dodge Dart GT
hey all, working on redoing the fuel line, i eventually plan on running a 4bbl with a well built slant, currently have a 3/8th setup when i get to the 4bbl will i need 3/8ths? thanks
PostPosted: Sun Jun 07, 2009 3:28 pm
I don't believe you'll *need* 3/8ths line but if you already have it there is no harm in keeping it that I know of.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Jun 07, 2009 3:55 pm
You do not need the 3/8's line. My last small block car was putting 423 h.p to the wheels running the stock 5/16's line.
PostPosted: Sun Jun 07, 2009 5:10 pm
ok thanks, i have the 5/16ths sending unit, but figured as long as im doing the whole fuel system over, may as well do it right if i need to eventually, just put together a 4ish year plan to get it where i want it, im counting on quite a raise the 4th year hahaha....crossing my fingers...
PostPosted: Sun Jun 07, 2009 11:02 pm
The 5/16" line is more than plenty and will reduce the workload on your fuel pump.
