| help on getting 22 PSi turbo setup https://slantsix.org/forum/viewtopic.php?t=35754 |
Page 1 of 3 |
| Author: | zerglin87 [ Mon Jun 08, 2009 5:25 am ] |
| Post subject: | help on getting 22 PSi turbo setup |
I got tired of my friends smack talking my slixer so i am gonna show them what REAL power is. What will I need for a bone stock slant six to have a 22 PSI turbo and be able to handle it? I would also like to know the road drivability and whatever. As it is also my daily driver ATM. I would like to know what turbo types you all put on your sixes for 22 PSI. I want to show my friends that the slant six isnt some piece of junk engine. PS I dont know jack about turboing a slant six. (9I heard there are hemi heads for the 225 slant six, any thing about that you all can tell me about?)) |
| Author: | 66aCUDA [ Mon Jun 08, 2009 5:48 am ] |
No Hemi heads for the slant, 4 major types (phases) but all work good. Only one that Really matters is the 81-87 as it is Hydrolic lifters, it wont swap to other years easly. As for 22 PSI one of the guys here is running that much. Frank |
| Author: | Andy's GT [ Mon Jun 08, 2009 6:09 am ] |
you probably heard about these: http://en.wikipedia.org/wiki/Chrysler_Hemi-6_Engine different beast. good luck on your project. |
| Author: | Rust collector [ Mon Jun 08, 2009 10:18 am ] |
Not that I have done much else than buying the turbo yet, but anyway 1. get a car to drive while you mess with this 2. uh...why 22? You could get that easily, if you made the carb/intake is restrictive enough, but the engine would not see that number... 3. you need a good fuel system I hope someone who has been there will say something |
| Author: | Shaker223 [ Mon Jun 08, 2009 11:02 am ] |
A buick GN turbo will do what you want and put the car into the 12s. You will have to fabricate everything yourself as there are no kits. As mentioned, you will need another car as this is not a weekend project. See here, here, here, and here, and here |
| Author: | Matt Cramer [ Mon Jun 08, 2009 12:15 pm ] |
Would that 22 psi of boost be because that's the limit on a 2.5 bar MAP sensor? Seriously, Shaker has a pretty good setup going. I'm working on building an EFI turbo setup myself, just trying to get the project back off the ground now, but I have a build diary on my home page: http://madscientistmatt.blogspot.com You'll definitely want to get another car as a daily driver for this; plan on it taking a lot more time and money than expected. |
| Author: | AnotherSix [ Mon Jun 08, 2009 3:08 pm ] |
Budget for an extra engine or two! Holding a turbo engine together is more about tuning than anything else. Nothing will keep it together if it is not set up right. |
| Author: | zerglin87 [ Mon Jun 08, 2009 4:25 pm ] |
Quote: Would that 22 psi of boost be because that's the limit on a 2.5 bar MAP sensor?
Of course It wont be a weekend job, but im just asking after i have it set up and tuned can I still drive it around daily like I would before i installed and tuned the turbo?
| Author: | Shaker223 [ Mon Jun 08, 2009 4:40 pm ] |
Quote: Quote: Would that 22 psi of boost be because that's the limit on a 2.5 bar MAP sensor?
Of course It wont be a weekend job, but im just asking after i have it set up and tuned can I still drive it around daily like I would before i installed and tuned the turbo?Seriously, Shaker has a pretty good setup going. I'm working on building an EFI turbo setup myself, just trying to get the project back off the ground now, but I have a build diary on my home page: http://madscientistmatt.blogspot.com You'll definitely want to get another car as a daily driver for this; plan on it taking a lot more time and money than expected. |
| Author: | turboram [ Mon Jun 08, 2009 7:53 pm ] |
I'm running a holset hx35 and that may be a cheaper turbo being it is an oem cummins turbo and a lot of diesel guys are tossing them in favor of a bigger one.tune it well and it will live no problem. have fun fabricating |
| Author: | turbo66valiant [ Mon Jun 08, 2009 8:43 pm ] |
Even mine is mild mannered. Is there such thing as a 10 second street slant six car? We may have to find out. Hope tomorrow is a nice day for a drive. Good luck with the build. Later, Ryan |
| Author: | zerglin87 [ Tue Jun 09, 2009 12:23 am ] |
If my car was 10 seconds i would catch up to the smack talking losers and go Death Proof on them. BTW any 4bbl carb anyone suggests? I am thinking of Edelbrocks atm After turbo setup can the stock /6 rear end handle the power? LOL I was thinking of putting taxi paint job on my dart call it "Jones' Screaming Taxi Co." or some stuff, maybe not we will see Oh and here is my specs 1971 dodge dart custom 4dr hard top All drum brakes. 225 /6 Holley 1920 1bbl A904 Automatic 3 spd trans. |
| Author: | Dart270 [ Tue Jun 09, 2009 5:39 am ] |
Edelbrock carb floats are supposed to crush above about 5psi of boost (blow through). You need better brakes... Cameron Tilley's grocerygetter/rocketship has run 10.69 @ 127 or so on ET street tires, and 10.90s or so on crap street tires. It looks and sounds like stock, and weighs about 3300 lbs. Lou |
| Author: | 66aCUDA [ Tue Jun 09, 2009 5:44 am ] |
I second Lou's "you NEED better brakes" Get some disc on the front at least. Frank |
| Author: | Shaker223 [ Tue Jun 09, 2009 6:14 am ] |
Check Here. That site will show you how to make a blow thru carb from a Holley or one of its clones. I have a Holley 600DP and turbo66valiant has a 575 Demon I believe. |
| Page 1 of 3 | All times are UTC-07:00 |
