| Newbie questions https://slantsix.org/forum/viewtopic.php?t=35819 |
| Author: | moper [ Fri Jun 12, 2009 4:41 am ] |
| Post subject: | Newbie questions |
Hi All, I'm new to slant sixes and early A bodies. Very well versed in pretty much everything else. I have a few questions. The subject is a '65 Barracuda with a /6, I think 225 but wont know until i see it Sunday. So if you can help with any, jump on in.. First, Does the later ('68-76) A body header P4529471 fit? That's the MP 6 into 1 long tube header. Second, will any of the later A 4sp chassis parts like the bell crank, pedals, and bellhousing work? I know the trannys are the trunion type but I'll be replacing the driveshaft and I think I have a couple slip yoke ones that would fit, plus a bunch of aluminum A833ODs. Third, I here the std A body 8 3/4 will bolt in, but I'm also told the leaf springs for later A's wont. Why not or is this even true? I think that's it for now. I'm sure I'll have more questions once I see the car. Thanks in advance! |
| Author: | 66aCUDA [ Fri Jun 12, 2009 7:10 am ] |
Welcome I can answer some of your questions. The headers wont fit with out some SERIOUS mods. 4 speed parts will work except the bell housing, you must have a slant bell. 66 you may not have the trunion mine didnt. A body 8 3/4 will bolt in. You may or may not need to move spring perches.depends on the year of 8 3/4. As for 225 or 170 engines look at the head to block heater hose. If 3 inches long 225, if 2 inches long 170. Or check the id pad on the block machine surface at number one cyc. |
| Author: | 65 dartman [ Fri Jun 12, 2009 7:51 am ] |
| Post subject: | Re: Newbie questions |
Quote: First, Does the later ('68-76) A body header P4529471 fit? That's the MP 6 into 1 long tube header.
It won't fit without a LOT of modification.Quote: Second, will any of the later A 4sp chassis parts like the bell crank, pedals, and bellhousing work? I know the trannys are the trunion type but I'll be replacing the driveshaft and I think I have a couple slip yoke ones that would fit, plus a bunch of aluminum A833ODs. You need to use 63-66 pedals. Quote: Third, I here the std A body 8 3/4 will bolt in, but I'm also told the leaf springs for later A's wont. Why not or is this even true?
Any year A Body 8 & 3/4 is a direct fit (except for shortening the driveshaft). I've got a 71 or 72 A Body 8 & 3/4 under my 65 GT convert. I'm pretty sure springs from at least 63 through 76 are a direct interchange - some are more heavy duty than others.
| Author: | moper [ Fri Jun 12, 2009 8:45 am ] |
Thanks Guys! |
