Alt. pulley removal ??
https://slantsix.org/forum/viewtopic.php?t=3582
Author:  GTS225 [ Tue May 07, 2002 8:31 am ]
Post subject:  Alt. pulley removal ??
Hi, guys. Trying to remove alt. pulley for bearing replacement/general cleanup. Didn't want to come off, and didn't want to apply excessive force. Any suggestions? ('78 dual-field version)
Roger
GTS225@aol.com
Author:  Charlie Schmid [ Tue May 07, 2002 11:11 am ]
Post subject:  Re: Alt. pulley removal ??
You need to use a special puller/installer. Parts store might have it for rent/borrow. However I have found it is usually more cost effective to purchase a remanufactured unit, with a warrantee.
: Hi, guys. Trying to remove alt. pulley for
: bearing replacement/general cleanup. Didn't
: want to come off, and didn't want to apply
: excessive force. Any suggestions? ('78
: dual-field version)
: Roger
flturbo6@aol.com
Author:  GTS225 [ Tue May 07, 2002 11:40 am ]
: You need to use a special puller/installer.
: Parts store might have it for rent/borrow.
Well, I tried a standard gear puller, pulling on the groove on the outboard end of the pulley hub, without success. Also started using bearing splitter, pulling from behind the belt groove....started to bend from the backside.
I suppose it is/was one of those items that was supplied to Mopar by Fisher Tools, wasn't it?
Roger
GTS225@aol.com
Author:  Bob D [ Wed May 08, 2002 6:25 pm ]
: Roger
A pulley remover and installer set sold by <A HREF="http://www.harborfreight.com">www.harborfreight.com</A> looks like it might work but I've never tried it. Type in "pulley remover" in the keyword search box. If you get one let us know.
Bob D
BBobbias@aol.com
