It is currently Mon Nov 23, 2026 5:54 am
PostPosted: Wed Jun 17, 2009 7:29 pm
I know about the hyd. lifters and non-adjustable rockers on the later engine.
'84 D100 has a burnt valve and I have access to a '68 225, a '62 170 and a '61 225 (I know about the sending unit as well)
Can I put the early head on the late block?
This is a "get me by" fix until the 360/727 goes in.
PostPosted: Wed Jun 17, 2009 7:37 pm
Use the 68 head.
PostPosted: Wed Jun 17, 2009 7:45 pm
You can use a mechanical head on a hydraulic block, but you need to changeover the camshaft and lifters to mechanical, and use mechanical pushrods.
PostPosted: Wed Jun 17, 2009 8:09 pm
See this thread
Danny
PostPosted: Wed Jun 17, 2009 8:10 pm
It's easier to just put the hydraulic valve gear on the older head and it works fine.
PostPosted: Wed Jun 17, 2009 8:54 pm
I can slap it together in a couple of hours. if it doesn't work I'm not out anything but some coolant and a head gasket.
PostPosted: Thu Jun 18, 2009 4:47 am
The early head will go right on the late engine. Use the valve gear (pushrods, rockers, shaft) from the lare hydro engine. The only thing that might be an issue, would be the rear rocker shaft bolt. You will probably have to use the early bolt to fit the head, and if I remember correctly, the hole in the shaft is smaller (just the bottom), and will need to be drilled larger. You will also have to use the early valve cover.
PostPosted: Thu Jun 18, 2009 7:16 am
this is what I thought, thanks.
PostPosted: Thu Jun 18, 2009 6:05 pm
I did this swap back several years ago, I had to swap the rocker arms over to the '68 rocker arm shaft to get around messing with that bolt. worked great :)
To each his own (so what if I wanna build a 450 horse MPFI turbo /6 instead of using a V-8!)
Users browsing this forum: Amazon [Bot], Bing [Bot] and 6 guests
