| Ball and Ball carb https://slantsix.org/forum/viewtopic.php?t=35901 |
| Author: | 225_wagon [ Thu Jun 18, 2009 8:27 pm ] |
| Post subject: | Ball and Ball carb |
I have a 65 valiant wagon with a 225. It has a single bbl Ball and Ball carb on it and I cant find any info on the BandB except that is was made for Chrysler. Any one have a link to site about these things? Thanks The only number on the carb I could find was 1695 Dont know if that will mean any thing to anyone. |
| Author: | SlantSixDan [ Thu Jun 18, 2009 9:12 pm ] |
Welcome on the board. Your carburetor is a 1-barrel Carter BBS (= Ball and Ball, Single). Carburetor operation and repair manuals (and some training movies) are posted here for free download. 1695 is a casting number, and doesn't identify the carburetor. The carburetor number would have been on an aluminum tag secured to the carburetor by one of the two front bowl screws. |
| Author: | 225_wagon [ Fri Jun 19, 2009 10:25 am ] |
Thanks Dan After pulling the carb I have more problems than I thought. I was going to do a rebuild and call it good. No such luck. I need a new carb. The air horn base is warped. After cleaning and replacing parts with the kit for that carb I found that the it is warped . So bad in fact that I can see daylight through the front of the body. Any sugestiond for a new carb? I wou;d like to stay with a 1 bbl. I checked Holley and I cant find 1 bbl on there web site. Thanks BTW After pulling the carb and cleraning it I found the Carter name on it. |
| Author: | radarsonwheels [ Fri Jun 19, 2009 5:41 pm ] |
| Post subject: | Never knew that! |
I always thought bb was some strange symbol for 'barrel' I have a ball and ball carb on my b model pickup with flathead 230 dodge engine- had to rebuild the acc. pump with hand made leather parts. Maybe I should have just re-used my old slant carb! Thanks Dan! |
| Author: | Rug_Trucker [ Fri Jun 19, 2009 7:18 pm ] |
BBS BBD bbl |
| Author: | Rug_Trucker [ Fri Jun 19, 2009 8:25 pm ] |
Quote: I need a new carb.
All the BBD's are that way too. I run them on a belt sander to flatten them.The air horn base is warped. After cleaning and replacing parts with the kit for that carb I found that the it is warped . So bad in fact that I can see daylight through the front of the body. I try and collect all the BBD's I can. I am going to start collecting the BBS's. Come to thing of it |
| Author: | walpolla [ Fri Jun 19, 2009 10:01 pm ] |
........Come to thing of it
USELESS INFORMATION ...... I have a friend who runs a carburettor repair shop,and his shop CAT is named ... yep.... CARTER.(told you it was useless info) regards,Rod |
| Author: | snarl [ Sun Jun 21, 2009 4:25 pm ] |
http://cgi.ebay.com/ebaymotors/DODGE-PL ... 240%3A1318 |
| Author: | SlantSixDan [ Sun Jun 21, 2009 5:24 pm ] |
1. Link doesn't work. 2. We don't post eBay's long garbage-filled URLs here. Please post eBay links in accord with directions in this post. Thanks! |
| Author: | 225_wagon [ Mon Jul 27, 2009 11:37 am ] |
What other single bbl carbs can i use with my existing intake manifold. I am having a hard time finding the info I need. Thanks |
| Author: | Aggressive Ted [ Mon Jul 27, 2009 12:37 pm ] |
A Carter BBS or a 1920 Holley. |
| Author: | 225_wagon [ Mon Jul 27, 2009 12:51 pm ] |
Thanks There is a member on here that has a 1920 he will sell me. |
