It is currently Mon May 11, 2026 10:11 pm
PostPosted: Fri Jun 26, 2009 10:31 am
Does anyone know of an easy & cheap way to dermine about how much ethanol there is in fuel? Around here it's supposed to be 10%, but has varied up to 50%.
PostPosted: Fri Jun 26, 2009 11:23 am
Briggs & Stratton part number 10023, alcohol percentage tester, should be under $10. This site has it for less than $5. It's a calibrated test tube: Put gasoline up to the fuel mark, add water to the water mark, cap, shake, let it settle for a few minutes, and directly read the alcohol percentage.
PostPosted: Mon Jun 29, 2009 3:59 pm
Thanks- it's rather obvious when you think to use water to extract the ethanol. I'll let you know how well it works.
